for a wideband where would u tap in for power?
if you were trying to get 12v power where would you tap into so you get the right voltage? is there anywhere on the inside on the passengers side the fuse box there i could tap into? any idea's to run it somewhere w/o any headaches?
also i am running it right now off the stock boost gauge and another gauge and i am thinking it is giving me false readings if not maybe my sensor is messed up. i tried un-plugging the other two gauges but it still seemed it was giving odd readings.
3rd^^
you can tap it off any fuse that would normally get power when then the cars on. i would run it off the sunroof or radio fuse on the fuse box that on the passanger side floor in the car, shorter wire to run and plus you wont have to go threw the hassle of getting it threw the damn fire wall except for the sensor wire and once is hard enough, to be able to tape it into the fuse box dont be ricer and take the wires and push them in with the fuse holding it, go to the local auto store and buy the thing you need it called a fuse along, it should run you like 5-7bucks, its like an inline fuse but it looks like a fuse with a wire running of it so you can put it in the fuse slot.
3rd^^
3rd^^
n20saturn
09-30-2015 12:26 AM
