wierd issue
wierd issue
my car is misfiring in cylinder #3 and Cylinder #1 but only at idle with the ac off when i turn on the ac at idle it doesnt misfire at all anymore and i don't misfire at all when the car is moving wierd or what how do i fix it i got hp tuners if its a tuning issue
2006 Victory Red Cobalt SS/SC
Fujita F5 CAI, ZZP ceramic header, ZZP 2.5 Downpipe, GMPP Sport exhaust, Aeroforce Interceptor gauge, AEM Wideband UEGO, HP Tuners, and Ingalls Torque Damper, 60lb injectors, 2.8 pulley, NGK iridium 2 steps colder, and gm shortened belt.
14000 miles
its not the plugs i switched them and it didnt make a difference
14000 miles
Last edited by Georgekillsimports; 12-05-2007 at 03:38 PM. Reason: Automerged Doublepost
i am sorry to be repedative, but what did you gap your plugs at?
never mind, they say not to gap those..
you can try swapping injectors around, maybe 2 of them have some **** stuck in them... see if the problem moves with them...
you know area you deserve a +rep you are so right too bad i figured out stock min pw is too low like .0904 i raised it to 1.102 and it is not misfiring but i have been retuning maf for like the past 2 hours almost got it settled again. but thats for the help
i found out the problem by comparing my car with the ac on and with the ac off
stock 0.904
stock 0.904
Last edited by Georgekillsimports; 12-05-2007 at 06:35 PM. Reason: Automerged Doublepost
