Will this resonator fit? Vibrant Ultra Quiet
Hi - looking to replace my ZZP resonator with this one. The length is a lot shorter but the width is what concerns me. Anyone know if it will fit in between the heat shield?
Vibrant Performance ::.
Inlet Diameter: 2.5"
Outlet Diameter: 2.5"
Body Width: 6.5" x 4.75"
Body Length: 9.75"
Overall Length: 13.75"
The ZZP measures:
Our 2.5" version measures 29.25" end to end, with a 24" x 5.25" body.
Thank you
Body Length: 9.75"
The ZZP measures:
Thank you
I would be careful with the Vibrant unit; they had a "stealth" series muffler that necked down noticeably inside, which would cut flow.
Not sure if the 6.5" width would cause an issue.
How about a hefty magnaflow with a 5" round body, there's a few different lengths on their site.
CobaltSS 16 (11-26-2015)
if you want to keep it quiet like the zzp one did you will need something longer than that vibrant. i myself run a magnaflow, its a 6" round x 24" body. its super quiet. however a 6" body is very tight in our tunnel and it hangs down. i have taken one out already on speed bumps. a 5" body would be better
The following 2 users liked this post by Sharkey:
Coba (11-25-2015),
dennis69
11-10-2015 02:38 PM
