will this throw a CEL?
You will have a P0420 code I believe which is because you do not have a cat. If the CEL comes on, which it will about 50miles after you install it, then simply unplug the battery for 5 mins and put it back on. That will clear the code. OR you could just simply buy an interceptor gauge and clear it from inside of your car right away.
an interceptor is a gauge, like your boost gauge, that shows you A LOT of different things about your car. I highly recommend you get one. It shows iat1, iat2, which is where i leave mine at, it also scans for codes, clears codes, and shows a lot more, has a shift light, etc. Its pretty cool.
below the steering wheel and connecting a separate included wire to a switched 12v
vehicle power source. Virtually plug-and-play!
source: http://www.aeroforcetech.com/Redline_Cobalt_tech.html
