will this work
will this work
i was wondering if the Cobalt S20G Turbo Oil Solution from hahn is universal and will work with other turbos?
Yeah it will work but it's not the best way. From what I understand the turbo oil drain should be above oil level. The hahn setup sends it below oil level.
But your in luck. The is a part on the main girdle of the lsj that Saab uses as it's oil drain. It's perfectly positioned for an oil drain. All you need to do it drill and tap it.
