Worth the money?
rotated mounts help wheel hop but the inserts end it. Optimum performance run both! getting the axles aligned with rotated mounts is a must if you have lowered your car.
theyll stop your wheel hop. I got the TTR version in my car with TTR upper mount and NO wheel hop. I could launch from redline and it wouldnt wheel hop. Just spin. Problem solved.
Go with the TTR or the ZZP ones if you want to save money go with the TTR ones cause they are a little cheaper but if your gonna buy them one at a time for money issues then go with the ZZP ones
