WOT box help
WOT box help
was looking into getting one. heard it was best for a vheicle without cats. mine has them tho. im barely ever going to use it but is it safe to run the WOT box and not have any issues down the road? Thanks
Vince over at trifecta is trying to make a no lift shift option and a rpm launch option for our cobalts. Give him a little bit of time before you dive in on the wot box thing.
Last I heard he was doing pretty well. He is thinking about trying to make a knob on the dash that would allow you to change the rpm you could launch at which would be kick ass. I personally wouldn't use the no lift shift option, but a launch option would be kinda nice although I have no problem keeping it at 2k when I launch.
well like i said im barely ever going to use it. only when i hit up the track like twice a year. so that 1/4 mile should be fine with my cats and a wot box or not? but yeah id like to have the trifecta thing where its just right in the pcm of the car vs. adding a wot box. but idk thats why im asking peoples opinions.
Rent me! per hour
you have to reflash the box every 2 months, or it freaks for some odd reason. staying on the 2 step to long will cause a p0300 code. wot shifting a lot will kill a cat.
Oh and by the way, Clear Image doesn't use a magnaflow cat and they say that it is not made in ceramic inside. Stainless steel I think... would this make a cat more durable with the wot box???
I think he means wot no lift shifting can kill a cat. I don't know why normal shifting at higher rpm's would kill a cat. I have a high flow cat and I have done a TON of high rpm shifts and my cat is still running correctly.
