wot box with nitrous?
i know its really bad to be spraying and hit the rev limiter.. well the wot box has the no lift shift.... so what im getting at will i be able to use the wot box while spraying?
It will work perfectly. All you have to do is wire in a relay from the clutch position switch so when you push the clutch down, it will cut power to the nitrous solenoids.
That may not even be a factor. You may want to check some noncobalt forums to see what others have done. But, I think you could pray and wot shift with no problem. I would expect a nice fireball every shift though.
^^ well the limiter is different. That cuts fuel but retains spark, which causes a lean condition when spraying nitrous. That could be very bad. If you wot shift then I figure it will all just get blown out with the extra fuel like normal. I have limited knowledge when it comes to nitrous, but the mixture going through your motor with no spark doesn't seem to be a problem.
