wow! anyidea?
Old 01-12-2010 | 05:30 PM
07ss|sc's Avatar
wow! anyidea?
so was comming home from work and was in first gear just coasting.. gave about a half throttle pull push the clutch in.. and now every gear it just grinds.. you can si out of gear rev and no grind.. push clutch in no grind.. put it in gear with clutch in no grind.. let clutch out in gear.. and grinds grinds grinds.. any ideas what it could be? thanks my guess.. clutch but hoping transmision because my clutch isnt coverd by warenty haha..
Old 01-12-2010 | 05:37 PM
SKCobalt's Avatar
I wonder if your shifter linkage is shifted or out of adjustment. If it is out then it would be partially out of gear when you select a gear, so when you let out the clutch you are grinding.
Old 01-12-2010 | 05:47 PM
07ss|sc's Avatar
that makes sence.. umm how would i check this do you know?
Old 01-12-2010 | 06:08 PM
LS6Rally's Avatar
might be Linkage, but is it every gear? if so my thought would be towards an input shaft. but idk, doesnt seem that that would break it.
so agin is it every gear. just 1,3,5. or 2,4,R? or all 6
Old 01-12-2010 | 06:15 PM
07ss|sc's Avatar
it is all them haha.. not a single one works all grind..
Old 01-12-2010 | 06:21 PM
SKCobalt's Avatar
Not to sure on how to check the linkage adjustment. I would think that one of the how to's for short shifter install might show how to adjust the linkage.
Old 01-12-2010 | 07:18 PM
Schaeffer's Avatar
my guess is that the linkage is fucked or you broke your roll pin and its jsut hanging on by a thread(letting alot of play in the linkage.)
Old 01-12-2010 | 07:24 PM
nicksredline's Avatar
rool pin is my guess and maby more likely linkage.
Old 01-12-2010 | 07:27 PM
Schaeffer's Avatar
when my roll pin broke it started of as grinding into 2nd gear then 2nd n 4th... then bye bye too all it was like a limp dick...lol
Old 01-13-2010 | 02:17 PM
07ss|sc's Avatar
so you did finaly loose all 5? and r?
Old 01-13-2010 | 06:55 PM
Schaeffer's Avatar
lol yeah. left me sitting in wal-marts parking lot at 230am
Old 01-13-2010 | 07:17 PM
Karlen89's Avatar
Might want to check that out before you get a new trans too.
Builttss
09-21-2015 04:29 PM
no_ss
09-18-2015 11:03 AM
Lorenzo
07-15-2005 12:24 PM
Quick Reply: wow! anyidea?
