ZZP Heat Exchanger
Old 10-14-2008, 04:50 PM
Sizzle06's Avatar
ZZP Heat Exchanger
Is there a how to on installing the ZZP H/E?
Old 10-14-2008, 04:51 PM
invisible's Avatar
It is pretty easy to do. I have a diagram of how the lines are supposed to be ran if you want it.
Old 10-14-2008, 04:52 PM
I'm too JDM for you
BLAZIN07SS's Avatar
be prepared to fight with the damn thing ZZP=horrible fitment. i should have gone with Over The Top Performance's kit
Old 10-14-2008, 04:53 PM
Sizzle06's Avatar
Would sure appreciate that,thanks
Did you remove the bumber when you installed yours?
Old 10-14-2008, 04:58 PM
invisible's Avatar
I didn't. Had plenty of room.
I'm too JDM for you
BLAZIN07SS's Avatar
yeah you have to. it mounts in between the crash bar and the frame
pic after i finished it^^^
i couldnt get the damn bumper to fit so i grinded down some edges behind the bumper. it was still a tight fit and it rubs on the bumper
Old 10-14-2008, 05:03 PM
Sizzle06's Avatar
Anyone else?
Old 10-14-2008, 06:01 PM
HunterKiller89's Avatar
mine fit perfectly....
Old 10-14-2008, 06:07 PM
lsjwannabe's Avatar
not the first i have heard of fitment error...
Old 10-14-2008, 06:09 PM
I'm too JDM for you
BLAZIN07SS's Avatar
the tabs for the 2 clips that go on the bumper dont even line up with the tabs on the crash bar, they are like 1 cm off in each direction. i shouldnt have been cheap and spent the extra 30 bucks on the OTTP kit
Old 10-14-2008, 06:14 PM
Sizzle06's Avatar
I had a $100 credit with them so i got it for$89+shipping or i would have gone with ottp.
Old 10-14-2008, 06:19 PM
SSdan's Avatar
Invisible can you post the diagram?
Old 10-15-2008, 05:31 AM
well, mine lined up....but if you want, just get 2 nuts from home depot that fit the side bracket parts, and tighten em down a lot. itll keep it straight and from moving at all. thats what im doing cause it was too much of a pain to get the bolts in at the time, and i was just about to take them back off for my new bumper anyway...
Old 10-15-2008, 07:13 PM
Supporting Vendor
Zooomer's Avatar
Our exchangers are built on a jig and all HE's leave here the same. I've seen customers post and say "it doesn't fit" and then I PM them and find out it's an issue on their end. As you can see, many people post "mine fit perfect". Obviously you all have the same car, so I'm assuming people who aren't used to modifying cars are possibly having a difficult time with an install that requires a little time.
The bumper skin should be taken off and I posted a how to in the vendor section. The ZZP HE is the lowest cost direct fit, custom made unit for the Cobalt. Members on here have reported excellent results and we've sold about 40 of them without a single return.
Old 10-15-2008, 07:19 PM
SSdan's Avatar
Zooomer if I wanted to run it without the stock unit do I need extra hoses?
Old 10-15-2008, 07:24 PM
Sizzle06's Avatar
Install was a breeze
Old 10-15-2008, 07:47 PM
Code5's Avatar
Did you find a way to install without removing the bumper? Any tips or hints?
Old 10-15-2008, 07:51 PM
you need one extra hose, and it comes with...suprise! one extra hose! i think it comes with a 6ft hose and come clamps.
Old 10-20-2008, 04:49 PM
Supporting Vendor
Zooomer's Avatar
No matter how you run it, you need the included extra hose and clamps. Glad to see others are not having any fitment issues. Just FYI, every unit is exactly the same so I believe that unless GM made your car different than other Cobalts, install should be easy.
Old 10-20-2008, 05:15 PM
zx2assassin's Avatar
I just installed mine this past weekend, it fit perfectly and no i did not need to remove the bumper. The only hard part was getting the old hoses off of the pump and factory heat exchanger other then that fiasco the install was a breeze.
Old 10-21-2008, 10:51 AM
SSdan's Avatar
I installed mine as well on Thursday, removing the stock HE.
Bumper was taken off which isn't even necassary IMO.
Getting the bumper to fit back in without cutting was a pain in the ass though.
And then 2 nights ago I plowed a cat and twisted the entire thing
Old 10-21-2008, 10:53 AM
ShortStack's Avatar
Dude NEVER plow a cat...
dogs are tighter...
Old 10-21-2008, 10:58 AM
SSdan's Avatar
Either way I was going 70+.
The cat ruined the ac condenser, radiator assembly, grill, bumper + lip, fog light, and the front mount.
I went back to find the cat but it was MIA.
When the car was towed we found hair in the subframe holes
Old 10-21-2008, 11:16 AM
ShortStack's Avatar
lol awwwwwww dude...... thats messy.
Old 10-21-2008, 09:37 PM
leviticus88's Avatar
Any trick to not removing the bumper? Thanx!
Quick Reply: ZZP Heat Exchanger
