zzp long tube Question
Old 01-16-2015, 10:12 AM
  #51
jamies06ss/sc's Avatar
So josh you think that because i went from 11.8 to 12.0 caused the 0 tq gain?
Old 01-16-2015, 12:12 PM
  #52
The other difference was i made peak power with the 2.7 at 7250, on a 2.6 with long tunes i made peak power at 6900
Old 01-16-2015, 12:20 PM
  #53
blueLNFftw's Avatar
Yes. Rich it up a little bit.
Old 01-16-2015, 02:57 PM
  #54
Administrator
Administrator
Staged07SS's Avatar
There's a thread on here about how pulley size affects where peak power was made.
The larger pulleys tend to make peak power higher up in the band, while the smaller pulleys made it a little lower.
I think the test was done on a stock cam car though.
Old 01-16-2015, 09:39 PM
  #55
I figured something like that, i had heard about the smaller pulley thing moving power band down. Also i seriously doubt .2 afr took awat 10lbsft or so away by itself.
Old 01-18-2015, 06:04 PM
  #56
Do you think timing is another issue? Saw one comparison where the lsj made more power at 25* vs 27* wot timing
Old 01-20-2015, 07:21 AM
  #57
Administrator
Administrator
Staged07SS's Avatar
Timing can change things as well....
Although, in h.o.m. with race gas, my car loves 26-27 degrees of timing.
Old 01-30-2015, 11:41 AM
  #58
This first one is my 2.7 graph, and it shows what installing a fresh rebuilt rotor pack will do to your power... kill it lolName:  20150129_173102_zps3hraj1lj.jpg
This is my 2.6, kinda bad pics, 279/250
Last edited by jamies06ss/sc; 01-30-2015 at 11:44 AM. Reason: Automerged Doublepost
ineedacobaltss
11-07-2015 02:25 PM
brandon04
10-21-2015 07:04 AM
09-27-2015 08:53 PM
jas09ss
09-26-2015 01:06 PM
ChrisTutoki
09-24-2015 08:39 PM
Quick Reply: zzp long tube Question
