ZZP Mid-length header/downpipe - nothing but problems
Hey guys,
I purchased the mid-length header/ downpipe combo back in march. as soon as i installed it, i had the header-to-downpipe bolts break off. didn't take longer than a couple hours for that.
btw, the product was a mid-length header to 3" downpipe with magnaflow hi-flo cat to 2.5" bolt in exit. and i have an ingall's tq dampener set to the tightest setting. the engine does not hardly move at all
since then i have blown out a total of 9 header-to-downpipe gaskets. it's the 3" 2-bolt style. I have tried every which way to seal this thing, including 1 gasket (4 times), 2 gaskets (2 times) and 1 gasket with sealant (1 time). finally i gave up on the gasket and decided to live with the constant exhaust leak.
then last night, during a moderate (not hard) launch, the damn downpipe just broke. broke clean off - right at the flange, leading to the flexpipe. here's some pics :
i'm so pissed right now.... i'm back to stock exhaust until i can decide what to do
Damn that sucks man. My zzp exhaust work was top notch. Went in without a problem and never had anything go wrong. Maybe contact ZZP and see if they are willing to help you out. Downpipes obviously shouldn't just break.
talked to them about the gasket issue, haven't yet talked to them about the busted downpipe since it just happened yesterday
but how does a weld come completely off like that? just a shitty defect?
This has been said over and over again. ZZP IS HORRIBLE when it comes to there exhaust department. They have rattling resonators, bolts breaking, and flex pipes breaking. Hungry and I have had this discussion before. My downpipe broke at the flex pipe also, as did many many others. They do not WELD there flex pipes, they crimp them. The 2nd one I got was tach welded, but its absolutely ridiculous at the amounts of problems they have.
The bolt problem should have been solved by now, you probably got shipped an older set of bolts. Other than that, I really don't know what to say. Call them, and get another. That's what I did.
I didnt bother calling them, I didnt want the same thing happening again later so i just got the old one cut out and a new flex pipe WELDED in like its supposed to be. Still haved fixed the leak yet at the downpipe resonator area. I'm going to try some high temp RTV silicone gasket maker, it also has copper in it. So basically ill make my own gasket. I might tackle that on tuesday
you can see in the pics that are just 2 little welds inside for tacks proble to hold it untill they crimp it.if you want to save your downpipe find a welding shop and see if they can weld it back and then u should have no problem!! other then your gasket but i have used the stuff from napa it comes in like a cheesewiz like can great stuff or someting gaskit maker i used it on my 98 s10 and its great stuff(because the flang was bent from welding it (heat worp) to the pipe.) and keep in mind stainless is wek after any weld and can brake!!!! thats just my 2cents after being at a auto body/welding shop for 7yrs.
thanks for all your guys' responses. i will be calling them first thing tomorrow and getting this taken care of. i will have them replace this one, which, after i get it, will probably take it to an exhaust shop and get the whole thing done the right way
As of early this month ZZP has changed the Downpipe design. Now instead of the flex pipe being welded or crimped directley to the flange the flange is instead welded to 2 inches of pipe and then connected to the flex pipe. They also found a flaw in there welding process so they have also fixed that as well. Thus all older model downpipes have a 2 year warranty instead of one for this reason. They should warranty it with no problem and send you the new design.
From: Voted by the people, most likely to get pulled over by a cop
I've head my mid combo on for about a month now and about a week ago it went raspy and I believe I have a pretty good leak. I'll get her in the air tomorrow.
