ZZP S3 finished.....idle probs no power HELP
#76
As in the laminova core O rings? So if the end plate gasket is bad how would coolant get to the air chambers and not physically leak on to the floor? I guess I will prolly answer my own questions when I pull it all off. Thanks For all your help staged. And your name is james? I'm Travis btw.
#77
I think that most likely the culprit. Or he barely torqued down the dual pass. Or he poured coolant in the top of the dual pass not thinking its an air bypass that leads directly into the manifold. Ask me why I would suggest that last part, stupidest thing I ever did while working on my car. had to take off the manifold and empty all the coolant I just poured into it. I felt like such a *******
#78
No problem Travis.
Let us know what you find.
#81
Definitely check those orings. I had the same problem with the car stuttering, except mine was a slow leak and it would only do it after I leave the car overnight, giving the coolant a chance to pool up in the manifold. It drove me nuts until I figured it out.
#82
Ok I didn't get the bi pass and I a hving the same problem I have the car on block instlling mounts but my injectors are 50s so they should have as much of an issue and I feel as a customer zzp is really dropping the ball on helping but that's my opinion. Can anyone explane ymy throttle ist consistant at all when I pu in the gas, throttle is clean and shiny s iknow its not that. I might haveto take it to the dealership and say have fun find the promblem and then if it is the cmputer I'm s.o.l. case they can't touch that, at least that's what they said
#83
#84
Are you continuing to lose intercooler fluid? If so that's a good place to start.
Fuel trim data would make things easier too. Those scan gauges are sweet. You won't be wasting money getting one of those.
#85
I got the fuel trims for him and they were reading +19%, i sent the pcm in to get retuned and it ran even worse
#87
See i dont know if im losing fluid cause i dont know if it really full, it seems like i was full but positive. Anyone know what the capacity of the stock system is and the S3 HE?
#88
I'm not positive of the hold capacity of the ZZP S3 heat exchanger.
My cooling setup is:
- OTTP Gen 4 Dual Pass Heat Exchanger
- GMR Dual Pass Endplate
- GMR Opt. B
I think I used slightly over half a gallon of coolant.
#89
Well i would assume the volume of OTTP and ZZP is equivalant, that being said i added 3/4 of a gallon to it after the install and only spilled about 2 cups. And it still is not topped off. O rings are my best bet. And it does seem as if im getting water out of my tail pipe, at 1st i thought it was just condensation cause of new DP and mods but maybe its burnt coolant. I checked it and had no smell but it did seem oily kinda. Hmmm all the fingers are pointing.
#93
Well fellas, i just pulled off the blower and there is definatly traces of coolant in the IM. So i pull off the IM and coolant poors out of it. So i take out the lamonova cores and crazy **** im missing one of the brass washers on one core. I am floored that i would have missed that before putting them back in, aside the fact i cant find it in my garage, clean floor and tidy area?. So im off the the parts store to see if i can match one up.What is the torque specs for the end plate? 89lbs?
#94
Local Napa said no chance of such size. FOOOOOOOOOOOOck. i cant believe i lost that.
#97
#99
#100
http://www.crateenginedepot.com/store/pdfs/sidekit.pdf
^All you need to know is in here (torque specs, install procedure, etc.)
