ZZP S3 finished.....idle probs no power HELP
Old 01-11-2012, 01:25 PM
  #76
I8URVET's Avatar
Damaged gasket or o-ring.
As in the laminova core O rings? So if the end plate gasket is bad how would coolant get to the air chambers and not physically leak on to the floor? I guess I will prolly answer my own questions when I pull it all off. Thanks For all your help staged. And your name is james? I'm Travis btw.
Old 01-11-2012, 01:31 PM
  #77
rivaladore's Avatar
I think that most likely the culprit. Or he barely torqued down the dual pass. Or he poured coolant in the top of the dual pass not thinking its an air bypass that leads directly into the manifold. Ask me why I would suggest that last part, stupidest thing I ever did while working on my car. had to take off the manifold and empty all the coolant I just poured into it. I felt like such a *******
Old 01-11-2012, 01:45 PM
  #78
Administrator
Administrator
Staged07SS's Avatar
My name is Jeff....
No problem Travis.
Let us know what you find.
Old 01-11-2012, 01:59 PM
  #79
advise's Avatar
theirs a total of 8 orings 2 per core and the 1 end plate gasket
you should pull of the manifold jump out your ic pump relay with the hoses on the intake manifold and see if its leaking coolant to avoid removing the end plate( aka pain in the ass) lol
best of luck
Old 01-11-2012, 02:13 PM
  #80
I8URVET's Avatar
Awesome help guys, I will order the PLX scan gauge and this weekend pull the IM and give it a look.
Old 01-11-2012, 08:51 PM
  #81
ChineseWop's Avatar
Definitely check those orings. I had the same problem with the car stuttering, except mine was a slow leak and it would only do it after I leave the car overnight, giving the coolant a chance to pool up in the manifold. It drove me nuts until I figured it out.
Old 01-11-2012, 10:46 PM
  #82
phelangcell's Avatar
Ok I didn't get the bi pass and I a hving the same problem I have the car on block instlling mounts but my injectors are 50s so they should have as much of an issue and I feel as a customer zzp is really dropping the ball on helping but that's my opinion. Can anyone explane ymy throttle ist consistant at all when I pu in the gas, throttle is clean and shiny s iknow its not that. I might haveto take it to the dealership and say have fun find the promblem and then if it is the cmputer I'm s.o.l. case they can't touch that, at least that's what they said
Old 01-11-2012, 11:30 PM
  #83
I8URVET's Avatar
Do you have a scan gauge? Tim says he can figure out a lot with the fuel perameters, i would say if your gonna spend the money to have someone figure it out then find a shop thats familiar with these cars if you can.
Old 01-12-2012, 12:05 AM
  #84
TimC@zzp's Avatar
Are you continuing to lose intercooler fluid? If so that's a good place to start.
Fuel trim data would make things easier too. Those scan gauges are sweet. You won't be wasting money getting one of those.
Old 01-12-2012, 02:11 AM
  #85
I got the fuel trims for him and they were reading +19%, i sent the pcm in to get retuned and it ran even worse
Old 01-12-2012, 07:07 AM
  #86
Administrator
Administrator
Staged07SS's Avatar
This.
Old 01-12-2012, 08:32 AM
  #87
I8URVET's Avatar
See i dont know if im losing fluid cause i dont know if it really full, it seems like i was full but positive. Anyone know what the capacity of the stock system is and the S3 HE?
Old 01-12-2012, 08:57 AM
  #88
Administrator
Administrator
Staged07SS's Avatar
Stock is like 2qts
I'm not positive of the hold capacity of the ZZP S3 heat exchanger.
My cooling setup is:
- OTTP Gen 4 Dual Pass Heat Exchanger
- GMR Dual Pass Endplate
- GMR Opt. B
I think I used slightly over half a gallon of coolant.
Old 01-12-2012, 09:07 AM
  #89
I8URVET's Avatar
Stock is like 2qts
- GMR Opt. B
Well i would assume the volume of OTTP and ZZP is equivalant, that being said i added 3/4 of a gallon to it after the install and only spilled about 2 cups. And it still is not topped off. O rings are my best bet. And it does seem as if im getting water out of my tail pipe, at 1st i thought it was just condensation cause of new DP and mods but maybe its burnt coolant. I checked it and had no smell but it did seem oily kinda. Hmmm all the fingers are pointing.
Old 01-12-2012, 11:07 AM
  #90
jrmotosports 88's Avatar
still in for final results....
Old 01-12-2012, 02:38 PM
  #91
I8URVET's Avatar
Yeah me too, just positive results.lol
Old 01-12-2012, 03:11 PM
  #92
so for nothing from zzp on my end still want my car to be drive-able my lil 2.2 cobalt just doesn't compare to my ss
Old 01-12-2012, 06:01 PM
  #93
I8URVET's Avatar
Well fellas, i just pulled off the blower and there is definatly traces of coolant in the IM. So i pull off the IM and coolant poors out of it. So i take out the lamonova cores and crazy **** im missing one of the brass washers on one core. I am floored that i would have missed that before putting them back in, aside the fact i cant find it in my garage, clean floor and tidy area?. So im off the the parts store to see if i can match one up.What is the torque specs for the end plate? 89lbs?
Old 01-12-2012, 07:51 PM
  #94
I8URVET's Avatar
And it turns out that washer/spacer in made of "unobtainium" GM dealer says it is a no serviceable part which means if you order a new IM you can get it that way...
Local Napa said no chance of such size. FOOOOOOOOOOOOck. i cant believe i lost that.
Old 01-12-2012, 09:27 PM
  #95
2006g85sslobalt's Avatar
F*** buying the stuff from gm $$$$$ just bite the bullet and get the single pass from zzp I bet its comparable in price.
Old 01-12-2012, 09:33 PM
  #96
mrbelvedere's Avatar
take on of the washers your missing to a machine shop and get one made out of stainless that is what i had to do when i lost one of mine and you cant get the manifolds from gm anymore
Old 01-12-2012, 09:35 PM
  #97
I8URVET's Avatar
Thats a beautiful idea. thanks mrB
Old 01-13-2012, 07:11 AM
  #98
Administrator
Administrator
Staged07SS's Avatar
Glad you found out what was wrong.
Old 01-13-2012, 09:46 AM
  #99
I8URVET's Avatar
Glad i found it too, just embarrassed that i did that cause i was so damn careful. Do you know what the torque specs for the end plate are?
Old 01-13-2012, 09:49 AM
  #100
Administrator
Administrator
Staged07SS's Avatar
**** happens man!
http://www.crateenginedepot.com/store/pdfs/sidekit.pdf
^All you need to know is in here (torque specs, install procedure, etc.)
Quick Reply: ZZP S3 finished.....idle probs no power HELP
