ZZP S3 finished.....idle probs no power HELP
Old 01-13-2012, 10:29 AM
  #101
I8URVET's Avatar
Kool, thats what i thought 89lbs. I just hope that this fixes all the problems. white smoke and stutter at 4k. I will keep you posted once i get a new washer made.
Old 01-13-2012, 10:31 AM
  #102
Administrator
Administrator
Staged07SS's Avatar
I'm sure it will!
It was choking on coolant, haha.
Old 01-13-2012, 02:30 PM
  #103
I8URVET's Avatar
Go figure, i go to the machine shop and have a $40 washer made. Get home and pull the cores out to inspect/clean/grease the Orings and clean out as much coolant as i can out of the IM and walla, there is my missing washer inside one of the paths in the IM. So i guess i left the bottom Oring in the IM and slid the core in with the washers on it and one must have fell of without me knowing. great news regardless. Im gonna make a necklace outta this damn machined washer. HAHA
Old 01-13-2012, 02:59 PM
  #104
Administrator
Administrator
Staged07SS's Avatar
Haha, you should!
Old 01-13-2012, 06:53 PM
  #105
I8URVET's Avatar
OK, so got everything put back together and followed Ps and Qs the whole way. Starts up fine, any throttle at standing still= tons of white smoke. gets worse with more and more throttle pops. Dies after taking it 4k. codes- P0122(throttle position sensor),P0172(rich), P0223(throttle position sensor high voltage),P1183(S/C inlet sensor low voltage),P2228(barametric pressure sensor low voltage) Any ideas guys. i checked all my harnesses 3 times.
Old 01-13-2012, 07:34 PM
  #106
I8URVET's Avatar
Im seconds away from going back to stock. This is insane.
Old 01-13-2012, 07:48 PM
  #107
05Slowline's Avatar
sounds like some wires got pinched or you have some bad parts.
if the tb is plugged in correctly it is bad, i had the same issue with the same codes, which will be half of the problem probably.
i hope you changed your spark plugs after getting coolant all over them and did an oil change.
Old 01-13-2012, 07:51 PM
  #108
I8URVET's Avatar
i didnt change the plugs because they looked fine( i pulled them to see) Why would i need to change to oil? i dont see how coolant can get to the oil. am i missing something?
Old 01-13-2012, 07:54 PM
  #109
05Slowline's Avatar
if your blowing tons of white smoke i'd say you got some in it somehow lol or maybe i had more to drink than i thought. u def have a bad tb or wiring though
Old 01-13-2012, 08:15 PM
  #110
I8URVET's Avatar
Well im gona be pist if ive got coolant in my oil cause that means head gasket. i guess i will change the oil and plugs tomorrow just to be sure. Thanks for your input for sure. So how does my TB just go bad in conjunction with all the other probs? coincedence?
Old 01-13-2012, 08:33 PM
  #111
05Slowline's Avatar
coincidence, i just looked at my dtcs from when i had the bad tb and i was wrong they were diff p0#'s but i would still say that's the culprit. you could try to pull the tb connector off and put it back on just to make sure, and clear the codes see which come back. lsj tb is cheap if it is bad though if you were closer i'd let you use my tb to find out .
Old 01-13-2012, 09:37 PM
  #112
mrbelvedere's Avatar
i believe the baro and skip sensors plugs can be swapped might want to check that and see
Old 01-13-2012, 11:00 PM
  #113
I8URVET's Avatar
baro? as in the barametric sensor?
Old 01-13-2012, 11:56 PM
  #114
yup
Old 01-14-2012, 12:42 AM
  #115
I8URVET's Avatar
yup
Geez its not a easy part to find, got it comin for $50 new.
Old 01-14-2012, 09:25 AM
  #116
why did you order a new one the plugin is the same swap them and see what happens
Old 01-14-2012, 10:02 AM
  #117
I8URVET's Avatar
where and what is the skip sensor? If its the sensor on the head just right of the fuel rail/injector #1 the wire is not long enough for them to be swapped.
Old 01-14-2012, 10:12 AM
  #118
smitzk01's Avatar
Curious to see what happens. I would def do an oil change and check for coolant. Also if you havent already clean the tb really good before you rule on it being bad. Finally, did you get new gaskets? If not maybe one of the gaskets is leaking and coolant is making it in through the intake mani that way, or a bad lama core. All else aside good luck.
Old 01-14-2012, 10:44 AM
  #119
I8URVET's Avatar
I did clean the TB good before reinstalling, did not get a new endplate gasket. as far as i can tell the only gasket that could allow coolant would be the endplate gasket. im gonna pull it apart again today and do an oil change and plugs, if there is coolant in the IM then i might buy a new/used one with a new gasket cause it could be a core too so i wanna rule out all the possibilities in the IM. thanks for the GL.
Old 01-14-2012, 10:51 AM
  #120
the scip is on top of the blower i had mine backwards
Old 01-14-2012, 11:49 AM
  #121
383_Stroker's Avatar
I had to look at an old picture to figure out which plug was which on my car..lol..
I feel your pain OP.. I managed to do the exact same thing on my intake, and I was just taking the cores out to clean them while i had the intake off. The steam was so dense when i rolled on the gas, you couldn't see through it..lol..
Old 01-14-2012, 12:13 PM
  #122
I8URVET's Avatar
oh i thought the sensor on top the blower was the Baro? where the hell is the baro then?
Old 01-14-2012, 12:28 PM
  #123
Its the one that makes it a pain in the butt to get your oil filter out.
Old 01-14-2012, 01:26 PM
  #124
phelangcell's Avatar
ok so i cleaned the map sensor and the car started up fine and ran good until it got hot. the car is now acting like it is misfiring! ZZP said that it might be the injectors they sent me or bad?? any ideas? I checked the spark plugs and they are gapped right so idk whats going on??
Old 01-14-2012, 02:02 PM
  #125
I8URVET's Avatar
Kinda same thing for me. but tons of white smoke when it warms up. I gotta dig into the oil and the IM to see if coolant is still gettin where its not supposed to. But the new codes are stumping me
Quick Reply: ZZP S3 finished.....idle probs no power HELP
