ZZP S3 finished.....idle probs no power HELP
Old 01-15-2012, 04:14 PM
  #126
I8URVET's Avatar
Update..
I tried to start it again today and cranked for a long time and no go, kinda smell fuel. So i pull the blower and low and behold my manifold if full of coolant, and i smell fuel directly out of the manifold as if its mixed with the coolant. Maybe just flooded from trying to start it. As for the coolant in the I/M im lost. there is waaaay more than before, should i just find a new I/M with cores and evthing. I assume the gasket for the dual pass is the same as the stock one? a new one didnt come with the dual pass. Any one have thoughts and know where to get a new IM?
Old 01-15-2012, 04:23 PM
  #127
rectorc08's Avatar
The dual pass gasket will be the same. I'd call ZZP on Monday morning and have them send you a new gasket. And if your looking to get a new I/M, check ZZP as well, they might have some used ones, if not mise well just go New. GL.
Old 01-15-2012, 04:26 PM
  #128
383_Stroker's Avatar
Pull it back apart and check for pinched o-rings, look your cores over and make sure they didn't get damaged when you removed them.
Old 01-15-2012, 04:40 PM
  #129
rivaladore's Avatar
Yea pull it back apart and take some pictures so we can see if we notice anything that you might be missing. When you swapped the laminova cores in the IM they went all the way in right?
Old 01-15-2012, 04:54 PM
  #130
phelangcell's Avatar
Originally Posted by I8URVET
Kinda same thing for me. but tons of white smoke when it warms up. I gotta dig into the oil and the IM to see if coolant is still gettin where its not supposed to. But the new codes are stumping me
Mine isnt throwing any codes anymore or having white smoke so im kinda at a lost the main difference between out problems is that u put the duel pass in and i didnt so on you problem i would start with that as for me im not sure were to start now.
Old 01-15-2012, 05:08 PM
  #131
I8URVET's Avatar
Yeah im going to, im gonna order new O rings and the gasket first tho, i do know that one of the cores was dented in the very end but only slightly, what kind of damage can happen to the rest of my engine with all this coolant getting in my combustion chamber? And for pics, ive never added any on here- do you have to use a pic service? photo bucket? copy paste the link for the image?
Old 01-15-2012, 05:33 PM
  #132
I8URVET's Avatar
Hey rectorc08, im not sure if you have a special phone # for ZZP but its always been- "leave a message and 2 days later they call back" if its a profitable call. i have had better luck emailing turbo tim.
Old 01-15-2012, 06:32 PM
  #133
mrbelvedere's Avatar
the laminova o-rings are 20 bucks each and you can only get them from the dealer they are an odd size like 36.5 mm or some **** like that
Old 01-15-2012, 06:33 PM
  #134
05Slowline's Avatar
yea email or pm is the quickest way they usually get back to you within hours on a business day
Old 01-18-2012, 09:21 AM
  #135
I8URVET's Avatar
Update..
So turbo tim is having me send him my IM and they are gonna pressure test it and seal it up.. Big thanks to tim and ZZP. Hope this works..
Old 01-18-2012, 09:25 AM
  #136
I8URVET's Avatar
sorry for the delay response. So yes the cores went in all the way and all the same flushness. im so lost on where the leak is, its gotta be the endplate gasket but im sending the whole IM to tim at zzp.
http://s1246.photobucket.com/albums/gg619/i8urvet/
Old 01-19-2012, 02:11 AM
  #137
update on my end i went to auto zone cause i though maybe my spark plugs were fauling out so i got there and there got new ones it called for and i think i got sent the wrong spark plugs cause i put the new one and it ran great no problems other than the belt slippage??? kinda wierd though
Old 01-19-2012, 04:29 PM
  #138
I8URVET's Avatar
What plugs did ZZP send you? (make, part #) Which ones did you put in from autozone? interesting!!! what did your plugs look like when you took them out? (black/wet/dry/white)
Old 01-20-2012, 06:16 PM
  #139
I8URVET's Avatar
Quick question, you know when you have your intake manifold off and you can look into the combustion chamber- are all four of the valves supposed to be even/at the same level? my fourth one to the right is lower than the other 3? i hope thats normal.
Old 01-20-2012, 06:20 PM
  #140
1AJeremyD's Avatar
yes thats normal. The engine on that cylinder is on a intake stroke
Old 01-21-2012, 02:10 AM
  #141
smitzk01's Avatar
This is why this site is the poop.
...just sayin.
Old 01-21-2012, 09:19 AM
  #142
thats not the combustion chamber that is the intake runner the valve is either openening for the intake cycle or it is closing for the combustion process
Old 01-21-2012, 09:21 AM
  #143
...just sayin.
if you dont like the site there are other places you can take your ******* to
Old 01-21-2012, 10:38 AM
  #144
I8URVET's Avatar
Ok, thank mrB and Jeremy, and as for you smit" **** off. If you know everything already than why are you even on here? Everyone is helping others in discussing there personel experiences, go somewhere else and bash. Sad thing is, how did you come accross this thread? uh huh....
Old 01-21-2012, 07:50 PM
  #145
smitzk01's Avatar
you mis-took me. I meant its the ****, just substituted with poop. This site is great.
and to OP I wasn't downing anything. you both took that the wrong way. This site is a great place to learn and to give/get advice. I posted that because I have learned while reading this thread. The information is the poop... meaning... its awesome.
Old 01-21-2012, 08:59 PM
  #146
I8URVET's Avatar
HaHa, def took it the wrong way. My bad for jumpin to early..
Old 01-21-2012, 10:25 PM
  #147
smitzk01's Avatar
It's cool man as I said in post #118 I'm in for results and good luck.
Old 01-24-2012, 07:13 PM
  #148
I8URVET's Avatar
Update: So ZZP received my IM and tim says "all of my cores were damaged from being removed" $350.00 ouch. i was pretty carefull but i guess not enough and having to pull them out 3 times ups the risk, lesson learned.
Will update when i reinstall.
Old 01-24-2012, 07:34 PM
  #149
05Slowline's Avatar
lol what did you use to take them out?
I know when i did my dual pass I was being careful as **** and i still put a small dent in one of them but never had any issues.
Old 01-24-2012, 08:06 PM
  #150
I8URVET's Avatar
i used a microfiber cloth and channel locks around that on 2 and my thumb inside the other 2 but it didnt take much so i didnt think it damaged them
Quick Reply: ZZP S3 finished.....idle probs no power HELP
