ZZP S3 only - bleed?
Im going to be only running the S3 HE and im wondering how to bleed air properly? Ill be installing option B so just keep filling tank till it stops taking coolant?
Cause i know the stock HE has a bleeder valve that you can use but the S3 does not.
its like bleeding anything else, stick your bleeder bucket down its throat and fill it, wait for bubbles to stop, expect to have to top it off several times over the next few days. if you absolutely refuse to buy the option b kit and bracket from zzp then you could just by the tank through gm, its basically the same tank as the regular coolant tank in the cobalt.
get option b. its short money and is awesome. if you just do the stg 3 he its bled through the regular means, the stg 3 sits lower than the factory he so it will bleed up into the factory he and you can bleed it from there and from the filler neck.
Got Bewst?
You won't say the same thing after you are done bleeding he system without an option b. Its a pain in the ass to get 100% of the air out. For the $100 you just drive down the highway and your whole system is completely bled in minuites. It's a cheap headache saver. Not to mention more fluid in the system. Option b FTW.
