ZZP S3 vs OTTP S1 Heat Exchanger ?
Old 06-02-2012, 03:06 PM
YelCal7's Avatar
Yeah, You may say look good but you are putting more weight on your front end. I rather ZZP cause it's only 6.4lbs rather than OTTP false advertisement heavy Chinese Heat Exchanger on your front end. You may say I don't want ZZP logo on heat exchanger. Simple use brake cleaner in any auto parts store and spray them off. That is what I research on that. I am gonna get ZZP and try brake cleaner. See if that works, LOL!
Old 06-02-2012, 03:09 PM
i went the ottp s1 route.
ive had it for <1 year so far, but its holding up great. SUPER easy install, just jack the car up, slide it in, bolt it on the frame, run the included hoses (confusing if u don't know what ur doing but still easy) and bam. H/E installed
Old 06-02-2012, 03:14 PM
its full of coolant so weight doesnt matter
Old 06-02-2012, 03:16 PM
^^its a pretty light unit anyways
05Slowline's Avatar
lol wut?
zzp holds more fluid afaik so filled they might be close in weight FILLED, but zzp is still holding more fluid. even if they held the same amount, 10lbs -> 20lbs, they're still going to have a 10lb difference when filled...
ottp weight is a guestimation since i never weighed the one i helped put on but it was heavy as fk.
Old 06-02-2012, 03:19 PM
weight doesnt matter to me*
forgot that part hehe
Old 06-02-2012, 03:24 PM
05Slowline's Avatar
Old 06-02-2012, 03:32 PM
YelCal7's Avatar
It does to me for MPG and lighter the more faster!
Old 06-02-2012, 04:03 PM
nhanson's Avatar
but more cooling capacity?
Old 06-02-2012, 04:12 PM
YelCal7's Avatar
Yeah, Will hold 1.8 fuild maybe 2lbs plus ZZP S3 HE 6.4lbs That total an estimate 8.4lbs. I don't see that will hurt MPG. Since my MSR 048 is 18.9lbs, compare to stock 24lbs each. I cut the weight 20lbs off the car then putting about 8.4lbs back on the car. I think I'll be fine.
Old 06-02-2012, 04:20 PM
  #36
well did u buy it already?
whats done to your car? any cooling mods already?
Old 06-02-2012, 04:30 PM
  #37
YelCal7's Avatar
Going to buy them. I am waiting for ZZP to email me back and see what they say about the deal that I asked them.
Old 06-02-2012, 04:31 PM
  #38
YelCal7's Avatar
Look in page 1 what I done to my car so far.
Old 06-02-2012, 05:28 PM
  #39
are u going to run two heat exchangers stock & zzp or pull the stock one?
u probably see pretty good iat2s already with the dual and opt b
i has opt b and running stock and the aftermarket one and my iat2s float about 20-30 degrees above ambient, outside temps
after a pull they recover fast aslong as im still moving
Old 06-02-2012, 05:47 PM
  #40
YelCal7's Avatar
And Don't forget Phenolic Spacers too. I am gonna leave my stock on and add ZZP S3 HE to it. I want it to be longer cooling and more pulling. LOL!
Old 06-02-2012, 06:21 PM
  #41
nhanson's Avatar
My IAT is the same as you.
Old 06-02-2012, 07:10 PM
  #42
05Slowline's Avatar
Crusing iat's don't mean a thing why do people still try to compare them
  #43
jonathan923's Avatar
F*** the HX, F**** the dual pass and Opt B F***meth, F***E85, just drop to a 2.6 n N2o nothing beats it.
Old 06-02-2012, 07:22 PM
  #44
YelCal7's Avatar
Crap, Are you trying to make us blow up our car? Hell Naw! I rather not! :-P
Old 06-02-2012, 07:37 PM
  #45
05Slowline's Avatar
lmaooooo
Old 06-02-2012, 09:22 PM
  #46
YelCal7's Avatar
Ok, If I want to remove factory HE and just run ZZP S3 HE then where am I suppose to put little clear hose from Option B Tank that bleed air out on ZZP S3 HE ? Cause I am seeing that ZZP S3 HE don't have it. It's made to run with stock HE to ZZP S3 HE.
Old 06-02-2012, 10:13 PM
  #47
05Slowline's Avatar
you'd have to get a fitting welded into the zzp i'/c but that's going through alot to do so, id just leave the stock inline also. having it out of line showed only a few deg difference when ottp tested it.
Old 06-02-2012, 10:20 PM
  #48
06cobalt racer's Avatar
Originally Posted by TStone
Pretty sure zzp did a comparison with all other heat exchangers.. But I have zzp s3 and it does a phenomenal job. I just don't like how the paint zzp on it :/ oh well. It does the job I want it to do
If you talk to them before you order they will leave it off.
Old 06-02-2012, 10:21 PM
  #49
Btw I have zzp s3.... I love it.
Old 06-02-2012, 10:30 PM
  #50
574
574's Avatar
Get the heaviest one you can, when you start making big powa you'll have more traction up front
Quick Reply: ZZP S3 vs OTTP S1 Heat Exchanger ?
