zzp stage 2 sc cams questions
not to thread jack but you think i should do stage 1 or 2 with my set up...i was thinkin 2 but not sure
if i get theses i will dyno before and after for sure!
im running 80s and meth and was @ 95% duty cycle on them but I was tuned on the rich side. all i did to the head other than the cams was gasket match the exhaust ports and put in ZZP's stronger valve springs.
i do not have dyno numbers so im not even gonna try to pull hp #s out of my butt
^ how is yours tuned then? street tune? My tuning is all a tad on the rich side too. Id rather have that small margin of safety than just a couple numbers that are higher than the other guy.
cam ll give hard time to your cold start
it may be difficult at each stop, you ll learn to manage it. you can get a higher rpm idling to counter this issue.
i m a 2.2 SC with stg2 N/A. have some bigger issue at idle since i SCed it but overall i like it.
cam are very easy to install when you use right tool JTOOL power.
it is a 45minute to 1,5 hours job. it is harder to change a exhaust manifold because no there is no room there
#41
if you r lucky like i did, you can get this tool for 0.01$ on ebay.
#42
#48
talked with ryan a bit about it. He knows my goals and what im aiming for with my car. He suggested the stage 2 cams(because of how much air the tvs pushes on the pulley im on) but i would want the adjustable cam gears to take full advantage which is what i figured. Cams, springs, port, bs delete, TVS, small pulley and a 8.2k redline= deep 11's for me. Everyone knows what i have run on the stock cams, i will see what ill run on the zzp cams and before and after dynos will be posted as well
#50
