zzp stage 3
zzp stage 3
i was lookin to get the zzp stage three supercharger kit for my 06 ss s/c. but my question is will i need a tune if i get the kit or will the pcm zzp sends me will that be good enough?
http://www.zzperformance.com/cobalt_...1055&catid=188
The ZZP S3 pcm will be tuned...
You will need exhuast work though (I/H/E)
ZZPerformance makes upgrading your supercharged Ion/Cobalt simple with our dyno proven Stage 3 kit. Stage 3 is designed with performance and reliability in mind. The PCM commands a flat AF ratio and drops timing slightly with decreases in pulley size. You will not lose AC function with our stage 3 kit like you would with the GM Stage 3 kit.
The zzp tune will get you to a tune shop , that is about all .. I just bought and installed thier kit and car idle was real bad (idle up and down by 100 rpm constant , never stops) and you smoke everyone out behind you !!! So if you get thier kit , leave money for a private tune
find someone with hptuners close by , lots of bad stuff on the net about trifecta nowadays that i have read ....hptuners is good hands on tuning and I bet won't cost you over 250.00-300.00!!!
