Zzp Tuned
Zzp Tuned
Just installed my ZZP LSJ PCM and i must say i'm pretty impressed with their tune.I went out and did a couple hard runs and it pulls pretty hard.Just wanted to thank ZZP for a great product and fast shipping!
i have 2 zzp tunes , they command 11.5 and most the time your a.f are lower than your comanded. they fuel maps seem to be on point i have a friend with a 2.8 and 42 pounds and his idc are 80 % at WOT mine are at 100 % and we both have 2.8 and 42 pounders.
cool thats good thats actually the first good thing i've heard about there canned tunes or any canned tune in that case
I'm just on the stage2 pulley from nates right now and i have a 2.8 waiting to be put on.I will probably wait till i get my wideband and to see if ZZP does a group buy for their H/E.
They tune it so you can run a smaller pulley down to a 2.8 an 42's.They tune to what you have on the car as far as injectors,cold air intake and if your running meth.
It came out to be $288 for everything but then when you send back your core they are supposed to refund you $125.I might just keep mine incase i have to go to the dealer for warranty work,i don't want to take any chances that the dealer might find out it's not the original pcm.Go to the zzp website and check it out if you already haven't already.
Well i can vouch for ZZP all the way i have been doing business with them since i bought my car, they are very good at helping out and working with you. I just did a retune with them cause i ported the blower and went to a 2.6 and they were fast. I had to overnight my PCM there and Overnight it back because im leaving on a road trip to tennessee tomorrow and they sure did what they said they would. once you get a PCM from them they Only charge 30 for retunes after that. Im running
Shortie header
3 inch exhaust
2.6 pulley
Ported SC
intake
Cobra H/E
60LB Injectors
Adjustable Tensioner
They just did the tune and limited boost in 1st gear by 50% and the A/F is 11.5
Shortie header
3 inch exhaust
2.6 pulley
Ported SC
intake
Cobra H/E
60LB Injectors
Shortie header
3 inch exhaust
2.6 pulley
Ported SC
intake
Cobra H/E
60LB Injectors
Shortie header
3 inch exhaust
2.6 pulley
Ported SC
intake
Cobra H/E
60LB Injectors
