**taerae86 goes supercharged!**
Old 04-06-2012, 04:01 PM
  #201
taerae86's Avatar
Originally Posted by drumrush
I managed to fit a zzp 3in one piece intake on my auto which some people said is impossible, so don't give up!
hah, i'm trying....
Old 04-06-2012, 08:46 PM
  #202
Doomstar's Avatar
Neat.
Old 04-06-2012, 09:16 PM
  #203
Axelthered05's Avatar
go back and polish the valve cover jk jk
Old 04-06-2012, 10:51 PM
  #204
taerae86's Avatar
Originally Posted by Doomstar
Neat.
Thanks? Lol
I think I'll pass for now hahah
Old 04-06-2012, 10:58 PM
  #205
heathkidder's Avatar
Let me steal that strut bar i regret sellin mine lol
Old 04-07-2012, 07:59 AM
  #206
taerae86's Avatar
I <3 it
So I probably should have posted this last night, but everything is together...go to tune, everything is going fine until the car freaking dies. Battery completely dead. So we hook it up to a charger for a while, try again, won't connect to the car. Finnaly get it to connect and it goes to 100% then I get the same error message I got after the car died the first time. So now nothing turns on. The car wont do anything, says low fuel (prob cause it actually is low) and power steering on the dic.
I let the battery charger on over night, gonna redownload the tune and try again this morning...hopefully it works then...idk.
Old 04-07-2012, 09:02 AM
  #207
AzraelRaezier's Avatar
you my have to do a security relearn. its a PITA but heres the instructions VIA zzp
so if all else fails do this
How do I perform a security relearn?
*1.*Disconnect battery
*2. Install new computer
*3. Reconnect battery
*4. Put emergency brake on to disable daytime running lights (this step is required!)
*5. Make sure all doors trunk and hood are closed leave driver window down and reach in threw window
*6. Try to start. If it doesn't start, leave the key in the on position for 10 min on 97-03 cars and 15 min for 04 and newer cars. The security light should turn*off after this amount*of time.
*7. Turn off ignition for 3 seconds
*8. Try and start*the car. It probably won't start. Repeat step 5 two more times.
*9. If this doesn't work disconnect battery*for 5 seconds and then try and start the car.
If that doesn’t work, try this one:
1. Disconnect battery for 10 sec.
2. Reconnect battery
3. Turn key to ON position
4. Do not try to start vehicle, just quickly click to RUN position to engage security light
5. Let vehicle sit with key ON for 35 min.
6. Attempt to crank vehicle. Once vehicle is running, the security light may still be on
7. If security light is still on, turn key to OFF position for 5 sec.
8. Turn key to ON position and security light should turn off
9. Start vehicle and enjoy new PCM
Notes: If your car starts at any time and stays running, you are done. If your car starts and dies, try step 9. If it dies after 2 seconds after you have done these steps, you either have a bad FP resistor or the security setting in your PCM is wrong and it will need an update. Security relearn procedure will not work with the valet key!
Old 04-07-2012, 10:12 AM
  #208
huckernage's Avatar
Originally Posted by taerae86
I <3 it
are u using trifecta?
are you using red cable?
is that a invalid file you get as a error message
you ll have to send TPL file to vince to analyse it. it should be around 105 Ko.
he ll update his ezfash software then you ll be able to install your file. it can be take a long time but it ll be fix
Old 04-07-2012, 10:23 AM
  #209
taerae86's Avatar
this is exactly the error message i get! thanks for the info!
Old 04-07-2012, 10:27 AM
  #210
huckernage's Avatar
if you have batt issue you should hook up a other car during the installation.
it is not a bid deal but it give my white hair when it is supposse to take 45 minute and not 3 hours to installing tune
Old 04-08-2012, 03:59 PM
  #211
taerae86's Avatar
my security light isn't on?
i didnt think i had a battery issue, i think the problem was that my car has been sitting since october and hasnt been started or anything, but i'm probably going to end up getting a new battery eventually anyway...
it won't even connect to the car, i get a message that says "unable to connect with the vehicle - please check the cabling and verify the ignition switch is on, but engine is not running." this is the error i've gotten a couple times. It only connected to the car twice, got to 100% and then gave me the invalid tune error or whatever. i've been talking with the trifecta dealer i went through and e-mailed him the TPL files and a screen shot of when it says unable to connect to the car, so we'll see...i'm not sure whether i need to send those files to vince or if he's planning on doing it. i'm waiting on a reply from him...
Old 04-08-2012, 04:08 PM
  #212
conerboner's Avatar
Mine won't connect sometimes but i usually just unplug it from my laptop and plug it in to a different usb port and try again and it has worked every time
Old 04-08-2012, 04:10 PM
  #213
taerae86's Avatar
tried every usb port on my laptop, as well as another laptop. i get the same message saying unable to connect
Old 04-08-2012, 04:20 PM
  #214
conerboner's Avatar
You double check to see if you have all the new drivers and what not?
Old 04-08-2012, 04:32 PM
  #215
i ran into this same issue. you have to do it in the correct order.
1. turn your key to the on position
2. plug cable into car
3. plug cable into laptop
4. open ezflash
i had to do this every time i uploaded my tune/datalogged.
Old 04-08-2012, 08:33 PM
  #216
huckernage's Avatar
you should send it yourself to vince and buy a black cable. you ll have TFT and you will not have to depend your dealer. if vince knew you were in trouble i m pretty sure he would fix that saturday even today.
when you SCed a 2.2 it is better to get a cable asap. i would not say that for NA application
Old 04-09-2012, 08:29 AM
  #217
taerae86's Avatar
yep...downloaded all the stuff on friday afternoon...
4. open ezflash
tried this...
damn it...if I would have known vince would have done something on a saturday, i would have went straight to him...when all this happened it was late friday night and i just figured he wouldnt do anything until at least today so i just figured i'd work with the dealer until then...but all the TPL files and screen shots got sent to vince so hopefully i'll hear back from him today, then...
TFT? i bought the red cable...
i read a thread on here and was told over at gmsc that if my car battery did die partially through the tune, i either need A) a new pcm, B) to take mine to the dealer to have it fixed and/or C) hope that Vince can fix it...i'm really hoping for C and am kicking myself in the ass because i wanted to put the battery charger on my car friday morning so it would have charged all day, but forgot before i went to work
Old 04-09-2012, 08:45 AM
  #218
huckernage's Avatar
tried this...
TFT? i bought a cable when i ordered my tune, but it's red, not black...
red cable give my white hair. i call this cable''Mordor cable''.
i prefer the black one that i call the gondor cable.
A) FALSE
b) False
c) true that the way it ll happen
you could unplug your PCM ECM fuse for few minutes.
i did over 62 customer with the gondor cable and no issue what so ever
but in 2012, the avg. to install is 3 hours by using mordor one.
always use a good batt because reflashing need more energie that you thing
you could jump your car with a other one.
Old 04-09-2012, 11:14 AM
  #219
taerae86's Avatar
A) FALSE
b) False
this makes me feel better! lol got an e-mail from Vince about an hour ago, so hopefully we're moving in the right direction...
i had the PCM ECM fuse out long enough to see it wasnt blown, then put it back in, may have to take it back out for a few when i get home...
i can believe that. When we tuned the bf's we borrowed the black box one from a friend and it went smooth as pie, loaded right on. Mine did not.
and i will definately make sure i have a good battery now...lesson learned lol
Old 04-09-2012, 11:30 AM
  #220
i have the tactrix cable and had issues when i wasnt doing it in the right order. but im looking into learning how to HPT but im lookin forward to seeing videos of the car running
Old 04-10-2012, 09:26 AM
  #221
taerae86's Avatar
i've never used the tactrix one... the one we used on the bf's had the black box and mine is red lol i tried every order possible and it would just bring up that same error. but i've been talking to vince and he's on it now so hopefully it will be all good soon!
i do have to say though, regardless of what some people may say, through my dealings with vince (both tuning the bf's and now with my car), he's been on top of it with e-mailing me back and such so far which i'm super happy about
Old 04-18-2012, 02:42 PM
  #222
taerae86's Avatar
he'll be running TONIGHT!
Old 04-18-2012, 02:48 PM
  #223
boosted05ss's Avatar
about time haha jk
Old 04-18-2012, 02:51 PM
  #224
taerae86's Avatar
i know, right? my new ECM came today, so as soon as i'm done with class, it's on
Old 04-18-2012, 02:57 PM
  #225
u still got ur first tune then right? i wouldnt drive it much till its fully tuned right
Quick Reply: **taerae86 goes supercharged!**
