06 2.2 engine
06 2.2 engine
i have a 06 cobalt with the 2.2L and the engine is bad iam looking at buying another used engine what year cobalt's can i use the engine out of i know they changed them at one point in time i thought but any help would be great does 2 or 4 door mater and auto vs stick i have a 5 speed in mine
I believe they changed the engine in 2009 model year. I think you can use any 2.2l from a cobalt before that. The number of doors doesnt matter and neither does the transmission setup as far as i know. Just make sure you get the 2.2l and not the 2.4l from the sport/ SS/NA model.
Go online and look up B&R auto wrecking, they ship engines and do a damned good job, i have a yard local to me, 658$ after core charge and tax on an 06 2.2 out of an HHR, came with TB, intake mani, exhaust mani, wiring harness, ecu, bcm, EVERYTHING from oil pan to valve cover
I have pics of the internal damage...none of it was immediate...wore down over some time and one day just **** on me
well it all started when i was taking my exhaust manifold off and broke the stud in the head well when i tried to drill it out from the front side reaching to the back side with a mirror i drilled threw the block and into the oil passage so when i cranked it over the oil was shooting out the side of the block instead of lubricating the cams dummy me so what i did was run a sleeve to cover the side hole that i drilled and jb weld it well see if it holds.
if you just need a head i got one layin around...only downside to it is that where the coolant hose goes to on it, my friend accidentally broke it. i took the piece and super glued it back on, but im going to add a little JB weld to be 100% sure its alright. so if you want it ill do $75 plus shipping, all you need is cams and the things that lock the cams down
I REPEAT DO NOT USE CAM CAPS FROM A DIFF CYL HEAD EVER!!!!
Exactly, just the same way you never swap main bearing caps between enignes. They are matched to the head or block. If you need to get new caps, then the head/block needs to be line-honed. Not ideal, and quite costly.
