06 cobalt 2.2l build questions
i have a 06 2.2l and wanting to build a motor for it but not use the original motor in the car what year blocks can i use crank and head. I know it hast to be form a cobalt i know 05 and o6 will work in my car but what about 07 with a o6 head any help would be great
I'm fairly certain 06 heads and 07 heads are not interchangeable, they added cam position sensors in 07 and did a few other things to the head. Safest beat is to keep the same model year parts together, but if you are trying to get an 06 head to fit an 07 block because of cams available for 06, the cams for 06 can be modified for 07 heads, there are a few threads about it on here, just search.
Are you planning on going turbo?
I was gona do a supercharger or 125 shot of nitrous I wonder if I just can't use a 07 motor and not run the cam sensor and chang over the valve cover to except my ignition
If you go supercharged i dont know if you need to build the lower end as long as you shot for around the 250whp number and dont beat on it every time you drive. There are some good supercharge build details in the sticky on supercharged and turbos
Can you not find a 06 block, or you just dont want to have to deal with getting the crank cyro'd and sleeving the block?
i cant find a 06 block and head i was just going to use a stock crank with forged rods and pistons with all the bolt-on and 125 shot i should be pushing 330 320 hp then i need a crank for a 5 speed i dont know if a 5 speed crank is the same as a auto
You can just cryo your stock crank, you don't have to buy one that is already done, and if your using a stock crank from a used motor I'd check your clearances and wear before you cryo. And you'll be down there anyways replacing the rods.
I'm not sure on the 06 block what the sleeves are rated too, I know 07 will hold till upper 400s, and they aren't the same as 06, 07s got stronger sleeves.
And I don't know much about running nitrous, but I'd ask a few questions under that section, pretty sure you'll need/should get a new intake mani with that shot.
