07 2.2 Exhaust Manifold
Why do you need a shot of the manifold? Isn't the '07 the same as the SS manifold? I have an '05 and '06 on hand but not an '07. There really isn't much of a difference though.
I thought they were the same, but going by looks they are not the same. Also they have differnt part numbers. On the ss/sc one I have the o2 sensor is on the manifold, and on my car the o2 sensor is not on the manifold, but its ont he the downpipe. Its not that big of an issue because I can get a plug for the hole in the dp after I put on the ss/sc manifold.
I could be wrong, but I'm pretty sure they started using the same exhaust manifold on everything in '08. I do have an '07 exhaust manifold, but it's on my car and I have no intention of ripping it off to take pics. Sorry.
Do you have one of the cobalts with two cats?
Correct i have two o2 sensors on my DP... which isn't so bad. Since I'm going to put on the ss/sc manifold, and plug the o2 sensr bung in teh DP it makes it that much easier if i ever get a wideband... i can just use the stock hole for the wide band sensor
