07cobaltguy's Re-Re-Build Thread!!!
Old 11-21-2011 | 05:56 PM
1LowLS's Avatar
Change your oil exsoccer lol jk
Old 11-21-2011 | 05:59 PM
EXsoccer1921's Avatar
there is also the weight advantages. mechanical weighs more. you also get rid of the tstat housing, lines, that annoying water line thats right under the turbo manifolds that people hate, oil cooler, hvac lines, ac condensor, compressor. theres about an 80lb weight savings(from what i weighed) plus the cooling benefits
07cobaltguy's Avatar
hahah funny how that works huh
What even funnier is that the morning i blew the car up i was going to take the truck to work and she got all pissy even though she had no where to go, so we argued about it lol then on my way home from work boom.. well i guess i HAVE to drive it now lol
Old 11-21-2011 | 06:01 PM
Originally Posted by ebristol
What are you doing for the block?
There is a Bare 07 Block on ebay for $150 unless i can find one around here. Thats all if the crank is still good. If not i will have to get a junk yard motor i guess.
Old 11-22-2011 | 12:33 AM
ebristol's Avatar
Interesting. Do you have any pics of the setup?
Old 11-22-2011 | 03:13 AM
yeah. those two above plus these.
no coolant line under the manifold.
block off plate.
mounting bracket.
coolant line that runs from the pump, under the engine, back up here. plus the waterpump block off plate
Thermostat block off
My entire belt system and a view of the line
oil cooler block off
heres a shot of the line to the radiator. plus how the engine bay looks without all the clutter of the hvac and coolant lines
Old 11-22-2011 | 10:31 PM
Looks interesting. I need to have heat though so doing the delete i think is out of the question Unless i pick up a beater which is a possibility.
Old 11-23-2011 | 12:02 AM
Leafydialupking's Avatar
Thats a no heat solution? Well there goes the plans of that for the first engine.
Old 11-26-2011 | 09:36 AM
Going to try to get the engine out today. I will have pics later.
Old 11-26-2011 | 09:58 AM
Updated First post with prices and vendors.
Old 11-27-2011 | 08:25 PM
  #36
ebristol's Avatar
You giving up on your build?
https://www.cobaltss.net/forums/part...bo-kit-266222/
Old 11-27-2011 | 08:35 PM
  #37
Wife is bitching so I'm seeing if it sells. If not then I will continue.
Found that the flywheel is cracked and the spec clutch is ****. So I have to buy new of both.
Old 11-27-2011 | 10:08 PM
  #38
Brags's Avatar
I hope you get to rebuild it. I know just like you how Shitty specs are on the f23. If you switch clutchmasters fx400 or zzp s4
Old 11-27-2011 | 10:15 PM
  #39
Yeah me too. This is my hobby and love i really dont want to give it up. I want to go ZZP and see if they will cut me a deal to be a test mule since i saw on the site that it hasnt been tested on a 2.2L and i need a new flywheel anyways since my oem one is cracked.
Old 11-27-2011 | 10:17 PM
  #40
40k miles on the clutch and its almost to the rivets maybe 1/64th left
Old 11-27-2011 | 11:24 PM
  #41
Sounds like par for the course with spec.
Old 11-28-2011 | 08:43 AM
  #42
BlackCobalt707's Avatar
sub'd. good luck with the build man. i hope everything goes good
Old 11-28-2011 | 09:23 AM
  #43
Brags's Avatar
At least your spec lasted 40k miles, mine lasted 5k then they blamed it on brand new GM flywheel.
Old 11-28-2011 | 06:09 PM
  #44
Well yeah... You didn't buy THEIR flywheel duh...
Old 12-02-2011 | 05:47 PM
  #45
well my wife told me to buy a winter beater so she can have the truck back and I can do what ever i want to my car. So i guess the build is on.
Old 12-04-2011 | 06:23 PM
  #46
thats always a good feeling
Old 12-08-2011 | 02:51 PM
  #47
Yes it is. Havent found one yet, but shes quieted down a bit. I got the motor out. I will post pictures in an update in a little bit. Im home sick from work today so i have a little bit of time on my hands.
Old 12-08-2011 | 06:37 PM
  #48
FIRST POST UPDATED:
UPDATE 12/8/11:
Well here are some pics from pulling the motor. I havent gotten the bottom end apart yet but i did get the head off. The valves in cylinder #1 are bent from the piston free floating in the cylinder. Luckly i have another head that i can canabalize for parts.
Also i am going to make a few changes and additions to the parts list. I am talking to ZZP about their LE5 clutch kit since my Spec clutch is now in the landfill.
Anyways on to the pics:
Old 12-10-2011 | 08:24 AM
  #49
Old 12-10-2011 | 09:04 AM
  #50
AyrtonSenna's Avatar
Link?
Because E pumps are expensive? Other then that I don't know.
I know you are just giving a possible answer to a question, but I hope that this is no true for people. If someone looks at it like that, building motors or modding cars is not something meant for him.
Quick Reply: 07cobaltguy's Re-Re-Build Thread!!!
