2.0 head on 2.2 block?
i'd reccomend a turbo grind cam. if you do a little research on the subject you'll find that the sc and turbo grinds are different when it comes to timing of course it'll work but i found that the sc grind is similar to na grinds and turbo grinds are modified to flow differently when it comes to the int. and exh. vavle timings cause they don't require exh scavaging. if you do go with the sc grind get a bov if you don't already have one.
09-28-2015 12:51 PM
