2.0 head on 2.2 block?
Old 02-23-2009, 12:20 PM
BlackCobalt707's Avatar
alright
Old 02-23-2009, 04:18 PM
HunterKiller89's Avatar
Originally Posted by Spanky's Monkey
i'd reccomend a turbo grind cam. if you do a little research on the subject you'll find that the sc and turbo grinds are different when it comes to timing of course it'll work but i found that the sc grind is similar to na grinds and turbo grinds are modified to flow differently when it comes to the int. and exh. vavle timings cause they don't require exh scavaging. if you do go with the sc grind get a bov if you don't already have one.
the blower grind uses the stage 1 intake cam and the stage 2 exhaust cam profiles The turbo grind, like you said, is a completely different grind though
Old 02-25-2009, 10:07 AM
Spanky's Monkey's Avatar
now that information i did not know. it actually helps if you can get those cams specifically, but you would need cam gears to dial em in right?
Old 02-25-2009, 11:07 AM
so are those cams sufficient for my build?
Old 02-25-2009, 11:12 AM
the blower grind would be good and you can find em at TTR
Old 02-25-2009, 09:01 PM
TTR? i forgot the full name
Old 02-25-2009, 09:34 PM
turbo tech racing
Old 02-26-2009, 11:45 AM
i dunno, he PMed me back when i asked him about the 2.0 head tho
Old 03-01-2009, 07:10 AM
constantproject's Avatar
subscribed...would like know mores aboot this as well
Old 03-01-2009, 10:45 AM
El Mariachi's Avatar
Originally Posted by BlackCobalt707
sweet. wat are the positives/negatives from doin the swap?
My thoughts exactly, why?
Old 03-01-2009, 02:46 PM
  #36
there really arent any benefits. the LSJ head BARELY flows more than the L61 head, and the valvetrain is the exact same excluding the valves.
05-28-2022 03:47 AM
ineedacobaltss
11-07-2015 02:25 PM
HEATON
10-16-2015 07:21 PM
Dylan Johnson
09-30-2015 08:57 AM
09-28-2015 12:51 PM
Quick Reply: 2.0 head on 2.2 block?
