2.0 injectors
Well the only mods i have right now are a injen cai cat back exhaust. there stock injectors from a stock SC. So you think its worth doing? any tuning needed once i put em in if i do?
if you dont tune, youll run hella rich, clog your cat, etc, etc...
it wont benefit your car at all unless your injectors arent spraying, either under high boost or high compression...
you could still install them if you wanted to run something like the AEM FIC to limit the pulse width, however since you don't have this and there is no benefit for you I would not recommend it.
09-28-2015 12:51 PM
