2.2 airbox mod
2.2 airbox mod
hey guys i was looking at chevy's website. they are currently coming out with a intake for our car.
http://www.chevrolet.com/pop/cobalt/2007/acc/air_en.jsp
thats it...wont a air box mod work, isnt it just really the same thing? any guys have that mod on our car? if so cudnt u just place a new filter in the pipin and leave it open to the air/heat soak? is this a good idea..need help
The GM intake appears to actually be sealed-off from the engine compartment. If you look at the pic, you'll see a 'baffle' around the cone filter, with a rubber seal at the top. That seal contacts the hood when closed, keeping air from the engine bay out of the filter-box. It mounts on the lower portion of the stock air-box, and draws air from the stock 'scoop' in the fender-well.
This is my issue with the GM intake. If it is designed the way it appears to be designed, its merely a conical filter attached the the stock plastic "piping." It doesn't appear like the GMPP intake will provide much of a power gain at all. Unless maybe the intake will come with a less restrictive air box then maybe the design makes sense, but as of yet no one knows.
*- Since I've only seen the pic on the Chevy website, I'm ASSuming this is the way it is set-up.
If i remember right the airbox mod is simply the top of the airbox cut off to fit a cone filter correct? If that is the case you will be sucking in the hot engine air and hurt the "performance" the intake. Unless you can find a way to seal the air so its cooler I would just buy an intake
https://www.cobaltss.net/forums/2-4l-le5-performance-tech-46/gmpp-intake-29339/
