2.2 Custom CAI Idea
2.2 Custom CAI Idea
Heres my idea. I have a short cold air intake from my old Dodge Ram. It has a good pipe on it that I will have to cut. My Idea is to remove the Clamp from the stock intake that connects to the filter. Cut the pipe to the right size to fit from that pipe to the filter box for my K&N. I will then drill holes to fit the MAF sensor onto the pipe. This way I can go back to stock with no problem. Just connect everything with the rubber sleeve and clamp it together.
You guy think this will work? Think it will look better then cutting the stock box to hell. Let me know what you think
i dunno bout that install..sounds a lil weird. i already made my custom CAI. sounds sick..responds amazing. this week ill be doing a ram air to it. tonio...hows ur exhaust goin..im thinkin for rite now to do 2.0 header and downpipe..ne thoughts? ill take pics of my intake when i do my ram air...i know u wanna see that. oh yeah i used that k&n e1009 filter..just like some ss/sc use...ill post pics soon.
Ok guys heres a little update for ya... I have sucess fully made my cai. My idea works great. I will be installing the intake tomorrow when the sealant finishes drying
selant...wut r u using buddy? i throw no CEL's with my custom cold air intake. when we first started the car up it was running rough due to the air sensor being off for a hour...the t/c light was on. then we pulled over. turned off the car and turned it back on and it went away. its runs amazing....any of u guys want the idea or part numbers...let me know.
ya i used sealant around the hole i made for the MAF sensor so no air would leak out. I want to hear about your icustom and the aprts you used
maybe thats my problem... sounds great but im throwing the Check engine light and traction control.....I used slicon sealant... What would you recomend using... I noticed when I had it on it was shifting gears real ruff too....I have an auto and it was jumping when shifting gear or even when I let off the gas...
Let me kow....I have enough piping to make another so when I get done and have no longer throwing CEL i will make another for someone..
Later
Later
Granger I had the same exact problem when I made my intake. Traction control light was on and the tranny was shiftting gears superhard! the problem was the air gettin into the censor So I put duck tape around the air pockets and the traction light and jumpy gears havent happend in a over 6 months...
Originally Posted by rallyyellow06
Hope you didnt damage the MAF in all of this, if you did have fun paying for the new one
THanks guys
wait did u cut out the mass air flow sensor??? and cut out a peice for it in the pipin for that old cai. on mine i kept that stock throttle body. no cel's wuts so ever. car runs amazin.
Yes, I did cut out a spot for the MAF sensor. Thats what the sealant is around. Tomorrow I am going to remove all the sealant and try to use duct tape. I would leave the bottom half of the box but my filter is to big. Im actually using a 3.5" pipe and K&N. (Old CAI form my dodge ram). I will let you guy know how it turns out.
Later
Later
2.2 Custom CAI Idea
Whoa Whoa man, you are making this ALOT harder than it should be. How Ironic this is going to sound probably complicated!
1. Get a 6" section of 3" exhaust pipe, about $3 if not free from any exhaust shop
2. Get your cone filter and a clamp for it
Now
Take the TOP part of your airbox off, you CAN remove the lower part too if you want, but this will work with or without it.
Now put the pipe in a vice..GENTLY, just enough to hold it still, put a thin block of wood inside the pipe near the middle and gently tap it with a hammer until it's flat, now take a little piece of rubber or gasket material and cut out the shape of the MAF. MAKE SURE that the MAF is mounted the same direction as the seam in the exhaust pipe because if it's horizontal and the seam is vertical, well your air isn't gonna flow into the sensor. Now slide your sensor in, use some tiny selftapping screws, make sure the FILTER side has the opening for the MAF showing. Now slide the filter on, slide the pipe in the stock rubber intake pipe and BOOM.
SHORT RAM.
If your going cold air...Get some 3" dryer ducting ($5), if you want, paint it black or hightemp or whatever and then get the same 6" section of pipe and cut/place the stuff where you need it.
I had just the short ram w/ stock lower airbox, pulled the lower part out..then decided to just use dryer ducting i had laying around instead of the big plastic part over the throttle body..and it works GREAT. I'll get pics for you. Email me at Piercingpsycho@aol.com.
It may sound complicated, but it's REALLY easy.
Now
SHORT RAM.
ya only thing i did was use the wrong sealant everything else is about the same other then my 3.5" piping.. im positive i didnt mess up the sensor because i didnt drive far with it on and then oi put the stock air b ox back on and alol my CELS went right off
yes my stock airbox is fully intact...and I just ordered a new airbox and filter. I have given up on this diea because I feel the Filter I have is worthless. I cleaned it inproperly and probably ruined it. I believe that is my prob. However i am now going to make a full intake with the airbox I just ordered. Im getting a AEM filter so I think I will work out great. Ill let you guys know how it goes and take pics for when it is done. Then I will make a DIY if it works out eprfectly
