2.2 dynos and times
#51
Originally Posted by qcpursuit
nice little setup slowion2,whats about the borla prototype exhaust?
Originally Posted by traviskearney
I'm scared to run a 1/4 mile. I finish an 1/8th at 8.3 @ 86mph. I use N20, and if I shoot at 108, bad news. I use a 75 N20 shot with a 55 gas shot. With the 75 gas shot, the stock timing, causes it to run ritch and I only gain 25whp instead of 72 with the 55 gas shot. If I use 55 and 55 shot I have 200whp. With 65 and 55 shot I have 212whp. With 75 and 55 shot - 222whp. If I could run a 1/4 without the fear of limiter, (everyone hate here and ignore the fact that 8.3 + 5.5 = 13.8) I would guess 13.6-14.3.
#52
Originally Posted by slowion2
Back about a year ago or so, Borla had decided to R&D a cat back for the 03-04 Ions. well, it looked pretty good, and quality was great, but being the cheap-asses that many Saturn owners are not many people had shown interest. As a result, the two prototypes they made were the only two for the Ion. A few months back, the two showed up on eBay. I snagged one, and another guy in STC (my car club) grabbed the other. I got it for around 165 shipped or so. I found out about a month after installing it, that Borla kept the design and just changed the flange and hanger locations, and is now selling it for the Cobalt for quite a bit more than I got mine
I find that very hard to believe as far as what power you're getting with the proper fuel jets. there's a good possibility you have just a really rich tune, which you can correct with a piggyback. sure, there comes a time (on a dyno which I'm assuming was when you did this) where you can try swapping jets and watch your a/f, but I don't see your correlation between stock timing causing you to run rich. ignition timing is not your fuel trim.
#53
you're suggested to retard timing to work against detonation, but considering how mild ignition timing is stock you can get away with running a 75 on stock timing.
haha I wasn't saying they made a piggyback for your car, but that doesn't mean you can't wire one in to work. For example: get your ecu pinouts and you can easily wire in a SAFC2 from Apexi or one of the many other afc's on the market. I come from a place where there isn't jack **** made for the cars we build, so it's either make it work or make it yourself. something still doesn't add up about your numbers though to me, just can't put my finger on it.
#55
hey guys with the 2.2 can any give me an idea on what rpm you launch at best ive been able to put down is a 16.2 and it seem every time off he line i either get wheel hop or it not high enough to get going so it bogs down
#58
#59
I have a dyno posted of 150.4, that's minus gas. I didn't have time to print out my N20 dynos while I was tuning, cause I wanted to get as many runs in, in an hour, so as not to pay another $100. But obviously adding 71 horses with a 75 shot, isn't impossible....so what's not to believe?
I hear you on the dyno cost too, those guys make money. there's luckily a few local to me that aren't too rediculous, but still more than I would have liked to spend.
#60
what's not to believe is what you say you gained with the correct jetting for a 75 shot if you really want to get technical, I really don't see how it's running that rich unless you have the wrong jetting info, but hey if it works and you're at the right a/f ratio then more power to you.
#61
#62
#64
[QUOTE=CivicKiller98]travis, what about using a progressive controller?[/QUOTE
That would be my foot, but the problem is, with the limiter being 108, I have to run slower than I'm really capable, and that doesnt give me a real time. I do an 1/8 at 86mph. Just from flying on the interstate, WITHOUT using N20, I know I can go from 86 to 108 in less than 5 seconds. So with it, it would be quicker of course. When I ran a "simulated" 1/4 on a dyno machine, I ran an 1/8 mile in 8.4 @ 82mph, and the machine "simulated" 12.6 at 112mph. But if I were to run, I wouldn't have full N20 the whole time, like I can when I run an 1/8th, therefore I would have to wait a little before I engage it, making my time probably closer to a 13.8.
#65
#66
progressive controllers simply pulse the solenoids, so with creative pedaling you can come as close (which isn't much in reality haha) as possible for a person to mimic the controller. a T-handle shifter with an intermittent buttom was the solution back in the day before progressive controllers were available.
accellerating from one speed to the next is not something that can compare to starting from a stop. but with the 1/8 mile time and traps you have (being thats not simulated) I could see that car turning mid 13's at 104-108. I'm working with the Ion ecus to get around that limiter for this reason, or at least bump it up a bit.
#68
maybe, everything we had been discussing on TSN and where ever else was just speculation because nobody did it. I had swapped an 05 flashed ecu into an 04 Redline and it took fine and did not cause a CEL, so that's a step in the right direction.
I just paid for another ecu today, picking it up within the next week or two from the guy. supposedly it's an auto out of a sedan, no idea the trim level. connectors are the same as mine now. either way I'll try it out and see what's up, then flash it a few times to see how it works out.
