2.2 ecotec in the uk
#54
#57
What size injectors do you have(lbs)? The smallest injector I would run with a 2.8" is 42lbs and that is with a good tune, but wold recommend 60lbs. With 60lb injectors and this supercharger you could run a 2.7 and still be pretty efficient as long as you have some cooling mods. With the 2.7 I don't think you are over spinning the blower at higher rpms, atleast not to bad.
#59
the lowest size pulley i would get with no cooling mods would be a 2.8, and it would still need a conservative tune. If you go dual pass and HE, then 2.7 is fair game, and an agressive tuned 2.8 is as well. I wouldnt drop below a 2.7 though unless your running meth in addition to all the other cooling mods. Actually, i personally wouldnt drop below a 2.7 regardless of cooling mods, but its really just preference. 2.5" was the smallest commonly run size, and they were considered to be pushingit, but pulleyboys makes pulleys as small as a 2.3
#66
i think he meant dual pass, as in dual pass endplate. ZZP has some info on how it works on their site, as do the many threads scattered throughout the forum. the cooler/bleeder tank i think he's referring to is the Opt B tank. check out crateenginedepot.com for that ones description, or again, search on here
#68
yes i have a header tank just like that now, also i have a full size charge cooler radiator (same size as my original radiator) with twin fans on it. will be wiring in a remote so that i can turn my fans on whenever i want (track use) also am getting the duel pass mod done very soon
#69
I know the 05-06 Ecu code is E16a here in the states I was wondering if yours is the same, cause it could possibly give us another tuning option. Are you on z22se?
#70
yeah z22se and to be honest, we havent even cracked the ecu other hear yet... although we have opened the doors to allow superchargers to be put on the 2.2 but nothing else really....
#71
hi, my names Joe and im from the UK.
i currently have a 2.2 ecotec vauxhall vx220:
my current mods are:
current mods
turbo spoiler
turbo side vents
turbo splitters
TAT long diffuser
fog lights converted to air brake cooling pipes
16/17 speedlines with r888 tyres
GAZ adjustable shocks
fast road GEO
engine mount poly-whatever inserts
mintex 1144 (soon to be 1155)
full 2.5" piper exhaust system with 200 cell cat and 4-1 manifold
ported head
+1mm wasted stem valves
piper cams (260 if i remember correctly)
m62 supercharger
75mm intake pipe with a KnN cone
courtenay sport custom remap
let injectors
Full aluminum radiator
small pre rad
lsj header tank
bosch water pump (for pre rad)
gearbox breather with air filter
oil catch tank with air filter
EGR cheater
near future mods
eagle rods
rebore and fit bigger weseco pistons
upgraded fuel pump
Harrop supercharger
double valve springs
fuel swirl tank
full size aluminum pre rad with twin fans
much bigger header tank for pre rad
balance deletion
lightened flywheel
4pot front brakes
harness bar
mog seats or similar
the current bhp at the wheels is 270
however this should be changing to about 360ish soon.
However this is where i need your help...
do any off you lot know what i need to change other than whats listed in future mods above?
any help is much apreciated.
thanks
current mods
turbo spoiler
turbo side vents
turbo splitters
TAT long diffuser
fast road GEO
ported head
m62 supercharger
let injectors
small pre rad
lsj header tank
EGR cheater
near future mods
eagle rods
upgraded fuel pump
Harrop supercharger
fuel swirl tank
balance deletion
lightened flywheel
4pot front brakes
harness bar
thanks
#73
speedster
hi you have a very nice vx i have one in malta 2.2 and i wish to make it turbo charged
now it is standard with little bits in the engine it makes 13.4 sec quarter mile
thanks
thanks
