2.2 + GM Tech After Hours =??????
ok so possible good news for us Syracuse NY area guys a mechanic at my job has a friend who will flash my computer in my car and my gf's i dunno if hes gonna give me a group deal but he said 200$ just for mine so mabe i can get a 2 for 1 so anyway what can exactly be done he said he will do anything i want all i know of so far is:
speed gov removed
rpm gov removed
secondary air injection removed
and hes going to tweak my emissions settings so i dont throw codes for my DP and header when i get it
what else can be done?
what is the best header to get now that im going to be able to get one?
my appointment is next friday after the shop manager leaves lol
speed gov removed
rpm gov removed
speed gov removed
rpm gov removed
speed gov removed
rpm gov removed
You can't remove spped governor/rpm governor with Tech 2.....
ok well id like more than 1 persons imput here i mean i havnt talked to this guy directly its all goin thru my co worker so what exactly can be done to my car while its hooked up to this thing
The only beneficial things you could do with a Tech 2 would be to remove SAI and to bump your car up to the 120mphs speed limiter by adjusting you to the larger tire size setting. However you should not be moving your speed limiter up without running the proper tires. It's dangerous.
agentirons
10-16-2015 02:11 AM
