2.2 injectors? asking for a friend
are there any out? or yall use the ss ones rewired and what not? my friend has a 2.2 and asked me but idk so had to ask on here. lmk thx
you take your stock harness, and cut off the plugs right at the end, then you take the harness that goes with the injectors and cut off the plugs with about 4 inches of extra wire and you scab them together. on each set there is a wire that is the same color and one that is diff (aka, all 4 injectors have a blue wire then each has one that is diff and same for the harness but they may use diff colors. so you take what HAS to be the ground in each and wire those together, then do the same with the other wire (power) and it will be good to go, rewrap, install and just cause not everyone knows it...get tuned...you have to get tuned for any of this to work
