2.2 Supercharger Build
Whent to junkyard today to get a head to get sent out but ended up getting a hole block for $150 love knowing people and u can never go rong whith a deal like that
That does look like a really small pulley lol probably at least a 2.7 maybe 2.6. If you build before going sc you could run those (although that small and heat and starts becoming an issue) but if you stay on stock internals first definitely get a bigger pulley lol
I'm doing full internals
finaly took the engin apart
This is y DEXCOOL is bade for your engin
Need to put trany flued in to get the cylinders free
I allso startd clening the head befor it hits the machine shop
starting to get ther
Sat at the junkyard in a satern for 2 years and now it's striped and redy to get rebuilt if I don't get the zzp block I only hot it for the head I only spent 150 on the hole block
#41
Thanks for the hot tank info and I'm building it cuzz the engin I have in my car now has bad compresen so I'm just building another engin for now and when I'm done I'll just throw it in
#43
the build is geting ther slowly
got the zzp Neutral Balance Shafts
[IMG][/IMG]
My Rocker arm came and valve gides
[IMG][/IMG]
[IMG][/IMG]
and my ARP head studs
[IMG][/IMG]
Its all geting the slow and stedy
My custom pistens should be in any day
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
#45
Don't use cosmetic head gasket!!!! Use factory l61 its multilayer steel and won't effect compression. I'm running a similar setup to what your building. Keeping factory compression is key. Your rods and pistons can handle it and you don't lose anything low end. If your going this far just delete balance shafts. I deleted mine and there's not much of a difference with vibration. It revs fasssst though. Never mind you already got your pistons. I just stuck with wiseco 10:1
#47
Just go with comp blower cams and titanium retainers. Me personally I wanna be unique so i m going with custom grinds. Its up to you. If you can go that route its cheaper made for you and no one else will have them. GM blanks are 80 and grinding is 120 a cam at least here. I'm excited to see the build progress though. If you wanna have fun you can swap to 07 stuff like me then you get hpt haha.
#49
swap ecm bcm and engine harness. then you have to rewire one ecm connector and repin 3 spots in your power distribution box. plus you need an 07 motor. the key things are the crank and cams. It's alot of extra work if you don't already have an 07 engine. I got mine for 200 bucks running hence why I did the 07 swap. plus you get like 15 more hp out of the 07
