2.2 tuning in the works!!
#126
Inches away from purchasing a Garrett GT3071R with the T25 exhaust flange since thats what my manifold has currently. Its also very small so i think it will fit right where my current turbo is and will support way over my power levels. The SRT4 guys are getting about a 3 - 3300rpm spool time on them which is fairly decent. But id like a 7k redline to stretch the power out a bit.
#129
after writing to hahn about the super 20 kit and him saying it would physically fit and some other things, i may go with that one because it has the portfueler kit.. that and hopefully this tuning, and id be good to go
then when i forge the interneals and do some other things i could really push the turbo higher, but i guess for now it would have to be turned down..
#135
325lbs torque gearbox
the tranny should still be fine depending on how i drive.. plus gm makes a performance auto tranny so either way if something did happen id buy the GMPP auto tranny
#138
Like 155 lb/tq
Its should hold fine as long as your not beating it up with wheel hop and burn outs. Get a decent clutch and axles and dont beat on it and it should hold out for awhile. I will be getting a second one to have incase something happens. I may be purchasing it from Dan(with the 1450hp build).
#142
I thought about the 6 speed thing also if i blew my tranny to bits.. i no a couple GM sites that have modded auto trannys and 6 speed trannys modified off the cobalt ones for way more power, i found them when looking at the GMPP trannies..
#144
from looking at the qualife 6 speed kit and maybe somehow getting a new housing and some other crap it may be able to work with some serious money.. to much money though.. looking at around 6 grand roughly from a estimated guess..
