2.2 turbo question
#51
whoa...hold on a minute....SAI or secondary air injection is only on the cars that are governed under the california emissions laws act. Not all 2007 Models have SAI....for instance...i have a 2007...Bought it brand new...it doesn't have SAI...ONLY THE ONES WITH CALI EMISSIONS HAVE THEM.....
yeah i don't see why cams won't be available....if you want i can make some calls today and find out
#55
I'm old school
Okay, a few more posts are up since my last visit...
First, SAI. Go read this --> https://www.cobaltss.net/forums/2-2l-l61-performance-tech-45/secondary-air-injection-late-production-2006-l61s-38488/
Its a great big sticky thread right at the top of the 2.2L performance forum that I wrote. It is an option only that came around the middle of the 2006 model year. There are still cars since then that don't have it. So if you want to get a 2008 without it, fine, go ahead, no problem.
The 2007 model L61 engine changes where to the head and exhaust cam. The cam has a slightly different profile, the head has slightly different ports, and of course there is the cam position sensor, which did away with the Waste-Spark ignition system in favor of a COP system. The extra power comes from those changes, not some magically different ECM program.
There is no flash tuner program available for either the 05-06 engines OR the 07 and later engines. Trifecta apparently can do BOTH. So if you want to be sure it's something they can tune, call them and ask. That way you can buy the newer car if you want. For the love of God, don't get a Cavalier. Seriously.
**** you. Seriously. You posted in here basically just to hear the sound of your own voice. Arrogant *****. Why don't you try helping the OP out instead of insulting him for not knowing as much as your all-knowing brain.
#56
First, SAI. Go read this --> https://www.cobaltss.net/forums/showthread.php?t=38488
**** you. Seriously. You posted in here basically just hear the sound of your own voice. Arrogant *****.
#57
I'm old school
The Cavalier is 1993 technology. The chassis, suspension, electrical systems, countless other items are far superior on the Delta platforms.
The late model Cav's have a PCM that is supported by HPT. No others that I know of, so I'm not sure what you mean by "plenty". But if Trifecta can do what they say they can, there is no reason to get a Cavalier.
All of the engine internals can still be used on the newer L61's except for cams. And honestly, the adjustable cam gears are better then replacing the cams.
There are two complete forced induction kits for the 05-06 Cobalts right now. Go read this:
https://www.cobaltss.net/forums/2-2l-l61-performance-tech-45/l61-turbo-super-forced-induction-information-thread-26325/
I can't argue the cheaper price. That's obvious since it's an older car. But you can easily find a manual trans on a Cobalt.
#58
https://www.cobaltss.net/forums/showthread.php?t=26325
#59
alright...yes the ECU was programmed different...i didn't say that was the only change...the 07 Year Model switched ECU platforms as you know...from the 16 Bit Platform to the 32 Bit Platform....
Trifecta can FLASH TUNE 05-07 COBALTS....L61/LE5 and LSJ in the Redline Ions....i should know this...if everything works well..i will be an east coast distributor for Trifecta. In my other posts about it, i have explained what the tune is able to do and i have also posted dyno sheets. These tunes are Dyno Proven and tested. They work and are good.
Cavalier comment....agreed...
#60
So with all that being said, would you go for the 06 Cobalt or the 07 Cobalt? You guys think within the next year or 2 they will have cams available for the 07's or 08's?
#62
I'm old school
#63
Even if they don't, I would still suggest getting the newer car for three reasons. First, the adjustable cam gears work on it. And that is an infinite level of adjustability. Just a cam without the adjustable gears means you are stuck with that cam now. And further, cams are really not that necessary, especially if you are going forced induction, but the ability to adjust their timing is. Second, the COP ignition is a more tuner-friendly engine. Third, if you still really must change your cams, then you can get your existing one re-ground. Yes, that is possible.
Don't misunderstand. I was saying there is no end-user, flash tuning program for either the E16 or E37. Then I went on to say that Trifecta can do it, but was trying to point out that they don't give the user a program to tune with. Instead, they make the tune and then send it to you to upload.
#64
I'm old school
Do adjustable cam gears give you any power? And do you get a lope? I'm not looking into F/I, I'm looking for a N/A build for now, then a couple years down the road go turbo. How is the COP ignition more tuner friendly when there is only 1 tuner out there now that will tune the 07? Getting it re-ground takes alot more time and I'm sure it costs alot more.
Using the adjustable gears for a N/A car will not help. They help tremendously on a F/I car.
The cam lobes (not lopes) cost for grinding would probably be the same whether you are regrinding an existing cam or grinding a blank cam. And probably cost less then buying a completely different set of cams.
Let me say that it seems you are bit hung up on the cam issue. It's really not that important in your N/A plans, especially if you plan to change to F/I later.
COP ignition is a bit more friendly due to the design compared to waste spark. It doesn't have anything to do with Trifecta's tuning ability or their software. It has to do with that cam position sensor. The 07-up L61 has a 53x reluctor ring on the crank and 4x cam position sensor. The earlier L61's had a 4x reluctor on the crank and sensed cam position based on the wasted spark impedance. I know, I know, very technical jargon crap. But simply put, making ignition and fuel injection timing adjustments is easier. Now since Trifecta will be doing all of those adjustments for you, you really don't have to worry about it too much. But if we ever get our own end-user tuning software, you'll appreciate the COP system better.
#65
If you plan to go turbo even as far away as a couple of years, don't bother with changing cams. Because whatever N/A cam you get will then not help you once you go F/I.
#66
I'm old school
No, I have a 2005. And what makes you think it's easier in the older cars? It's the same engine. Do you mean the tuning? Because using a program like HPT require a tremendous amount of knowledge. Having Trifecta make you a tune would probably be a lot less hassle actually.
#67
#68
I'm old school
Ya know, if you haven't already bought the car, have you looked at getting an LE5? That would be an excellent tuner car. Its the one thing I would have done differently.
#69
Hey halfcent, isnt it 60-2(aka 58X) on the 07+(including the LSJ's) and 7X on us prior year L61's? About the crank sensor reluctor rings that is.
I agree with that 100% man.. I wish i had gotten the LE5. its got the displacement and stout internals for a nice turbo build.
#71
I seriously havent seen any of them around here for sale, but like I said, I'm heading to Nashville on Sunday to check out some dealers.
#72
I'm old school
No, the person I was talking to, known as the "instigator" is the one that normally gets banned for that. He should be thankful I all I did was give him a tongue lashing instead of an infraction. And you should know better too as long as you have been here.
#73
comp cams has 07 cams...
its just a little longer cam, like an extra 3-5 inches or so, and the wheel that the sensor reads is pressed on.
i think when people see "cam position sensor" they say OMG that sounds important,, i dont wanna F around with that.. just think of it as a longer intake cam, with a wheel pressed on that has certain little pieces and whatnot that tell the sensor where the cam is at (very accurately)
