2.2 ZZP S/C Kit Issue
Well my car isnt starting. Drove to autozone and was going to leave and the car wouldnt start. Sounds like its not getting fuel. Looked at the injectors and injector #1 was covered in oil. ZZP gave me a crank case filter that I used and well the filter is very brown now and looks like it was leaking onto the injector. Pulled the injector and it was oil and slimy inside the injector connector harness and there was a small pool of what smelled and looked like oil just sitting in the o-ring seat. So now my car is stuck at autozone unitl I get it towed and I have no idea what to do.
So I bought a new relay and plugged it in and the car fired right up. Then turned it off and started it gain to leave autozone and when I went to leave my house the car wouldn't start again. Only thing I can think of is something shorting the circuit and blowing the fuel pump relay
Well thats the thing, I have had the pump wired to the same place since beginning of summer when I installed the kit and haven't had any problems. I'll double check though.
Only shitty part is the fuel pump is 270$ after taxes.
