2.2L Cooling System Help!!
I gotta pull the front end off tonight and see what all got messed up the other night when I slid into a ditch and tweaked the drivers side bottom radiator mount. Anything I should be looking for specifically or is it all pretty much straight-forward? I tried searching for answers, but didn't find anything pertaining to my situation.
Ok, everything looks fine. I broke a mounting tab off the bottom of the rad and bent the mount on the subframe.. Checked over everything else and it all appears to be fine. Getiing the P0480 code saying cooling fan 1 circuit has a malfunction.. Replaced the fuses and checked power to the relays, but it still trips the fuses for cooling fan 1 and 2...
ThoR294
10-04-2015 08:44 PM
