2.2l and Mobil 1 = blown motor?
when a DTC is set or a fault is found the ecm takes a snap shot of every parameter on the motor including oil pressure which can be viewed later with a tech 2. you can find out exactly what speed, rpm, oil pressure, fuel pressure everything from this snap shot. so my guess is they took a look at this when the vehicle was in the shop.
doubtful, switching from conventional to synthetic, Isn't a big deal, no matter the mileage. Also I would most likely say it was neglet on your company's part.
im going to go with neglect..
also you could send the oil in to have it analized. they would be able to tell you what went wrong just by looking at some of the oil..
ThoR294
10-04-2015 08:44 PM
