2.4 IM missing something?
I just got my new manifold and it doesn't have that extra plastic piece that I heard is needed. Do I need that extra plastic piece that is supposed to be on the inside where the TB would go?
For an 07
For an 07
he doesn't mean the adaptor plate, yes that small plastic piece that Maven mentions in his HowTo is required, otherwise the gasket doesn't actually seal anything. so yes you have to have it. but check and make sure it isn't tucked inside, mine was, and shake it a little bit and see if it came loose fell inside, you'll need a set of mechanics fingers to get to it in there though. good luck! great mod!
like stated it is probly inside somwhere, if not you need to either get ahold of where you bought it and get a new one, or get ahold of one if it was private party...
to the OP...if you bought it new send it back or call who you got it from and tell them it is incomplete. good luck...
z28addiction
09-28-2015 12:03 AM
