to 2.4 or not to 2.4, that is my question
#51
So you need:
Mounts
Axles
Intermediate axle shaft and beraring
Cables
Shifter(they work different, the F23 one will physically work, but not 100%)
Console trim( if different in the Ions)
Vehicle Speed Sensor harness(this is assuming the VSS reluctor wheel is the same between the two transmissions...I dont know if it is, if it isnt....your pretty much screwed.)
A clutch solution
A clutch actuation solution
To deal with the thermostat housing/coolant pipes
#52
the ions have a different center console than the cpbalt, and it's the same between the RL and regular ones. and as far as I know, the rest of it swaps right out except the axles, mounts, clutch disk/flywheel, and a couple other small parts, at least on ions.
#55
well i got the manifold in and i can say that it hauls to redline, no more sputtering after like 4k. only problem i have with the manifold is that now my injen TB elbow is touching the hood blanket when i close my hood. any ideas why? or is this normaal.
