to 2.4 or not to 2.4, that is my question
Old 03-20-2009, 03:27 PM
  #51
Maven's Avatar
Originally Posted by 2007 ion2
why do I need all that? I have an f23 all I should need is the mounts and axles, and maybe cables, but I believe they bolt right up.
You need a shifter because while they do swap, the F23 doesnt work 100% on the F35,the console trim because i beleive its different between the two shifters(I KNOW it is on Balts) Is that all youre questioning?
So you need:
Mounts
Axles
Intermediate axle shaft and beraring
Cables
Shifter(they work different, the F23 one will physically work, but not 100%)
Console trim( if different in the Ions)
Vehicle Speed Sensor harness(this is assuming the VSS reluctor wheel is the same between the two transmissions...I dont know if it is, if it isnt....your pretty much screwed.)
A clutch solution
A clutch actuation solution
To deal with the thermostat housing/coolant pipes
Old 03-20-2009, 08:49 PM
  #52
2007 ion2's Avatar
the ions have a different center console than the cpbalt, and it's the same between the RL and regular ones. and as far as I know, the rest of it swaps right out except the axles, mounts, clutch disk/flywheel, and a couple other small parts, at least on ions.
Old 03-20-2009, 09:46 PM
  #53
warrenb213's Avatar
2 different models of merc's.
Old 03-20-2009, 09:51 PM
  #54
blackbolt89's Avatar
so i got my intake manifold in today. anyone have tips for installing, if we need any special tools. anything?
Old 03-26-2009, 01:02 PM
  #55
well i got the manifold in and i can say that it hauls to redline, no more sputtering after like 4k. only problem i have with the manifold is that now my injen TB elbow is touching the hood blanket when i close my hood. any ideas why? or is this normaal.
Old 03-26-2009, 07:51 PM
  #56
warrenb213's Avatar
kinda interesting u say that. the top of the elbow of mine is barrrrely touching the hood blanket in mine as well, and that's without the 2.4 mani.
Old 03-26-2009, 09:26 PM
  #57
wait til you get the manifold. it's noticeably higher up. that's what made me check it out with a flashlight. unless i'm going crazy.
05-28-2022 03:47 AM
brandon04
10-21-2015 07:04 AM
patooyee
10-15-2015 05:11 PM
Extremespeed
09-29-2015 04:34 AM
Iceberg
09-28-2015 01:31 PM
Quick Reply: to 2.4 or not to 2.4, that is my question
