2.4 tb/intake mani
2.4 tb/intake mani
ok so iv been considering the 2.4 intake mani and tb BUT is it really worth it they look exactly the same?
how simple is the install and what else wil i need just besides those two things?
iv also heard the 2.4 intake mani is just as good with the 2.2 tb than the 2.4?
any feedback would be awesome thanks
i just installed my 2.4 intake mani, definitly seen an increase on the top end, but lost the wicked torque spike on the low end, kinda smoothed everything out lol, keeps pulling hard on the higher rpms tho, i dont have the 2.4 tb so i cannot comment on that, and if you have the 2.2 and 2.4 manis beside eachother you can see the difference
pics?
also are u the 6 pin or 8 pin or did u have to rewire?
im 6 pin but how hard is the install and WHAT ELSE WILL I NEED
iv seen a few diff. post such as a seal? but wouldnt the one i have work or what exactly?
why do i need a longer brake booster hose?
and i have a tune but yes id need a retune i no
i have no idea. i bought one complete with all seals and hoses, install was very simple, hardest part i had trouble was with putting the brake booster hose back on the brake booster lol, only thing you gotta do is drill the hole bigger for the map sensor or whatever it is
you need a longer brake booster hose as they do not attach to the same place on the 2.4 as the 2.2 on the 2.4 it attaches at the bottom of where the tb attaches to
im so lost about the brake booster hose i wouldnt even no wher it is unless im looking directly at it lol ANYWAY is there a place i can get one gmpartsdirect maybe? i may try gettin just the intake mani so i def. need a seal though
pics would help if you could but if not im sure i could figure it out its just the fact i like to get info on what to expect when i get it and already have a good idea of what im doin i never really have the smarts to "talk" bout engine stuff but once i get to doin it its usually simple
you will need the crank passage seal if it doesn't come with it and a new intake gasket and new throttle body gasket. The brake booster is easy I just bought a foot of 1/2" hose and extended mine. On the 2.2 mani it goes in the side of the mani and on the 2.4 it goes under where the tb is.
If you dont want to worry about possibly not having everything get the kit at Ecotec HO Intake Manifold Kit 2.2MMGF - Crate Engine Depot
It has every seal, gasket, adapter, you could need for any year balt and comes with a brake booster hose as well.
If I remember, he got ripped off?
no i just decided to be smart and save up for the zzp kit. or honestly i feel like jus doin bolt ons
catback
header
dp
2.4 tb
2.4 intake mani
few other simple mods and calling it a day lol
only cause i dont want issues in the long run i like my car how it is and idk if i could put up with it bein broke down or what not.
if i want to go fast ill buy a fast car lol
catback
header
dp
2.4 tb
2.4 intake mani
is this a must?
1. 2.2L intake removal (Allow engine to cool–do not remove when engine is hot). . Disconnect battery prior to starting work and/or clear the ECU with a scan tool. The ECU learns the throttle position and has set parameters for the original 2.2L intake manifold. This will reset the ECU and allow it to relearn new parameters with the new intake manifold.
is this a must?
