2.4L vs 2.2L K&N Intake
I know that the two are interchangable but I was wondering if there is a difference if I were to use the 2.4L(part #KNN69-4517TTK ) intake for my 2.2L(part #KNN69-4515TS?) I like the 2.4L intake as its black but what throws me off is the difference power gains between the two. Will I lose power by using the 2.4L or should I just stick with the 2.2L intake?
Also reason for going with K&N is that I have SAI.
thanks
thanks
the angles of the engine on the 2.2 and 2.4 are different. they're probably the same size, just different bends to compensate for the different angles. If i can recall correctly, the K&N pipes are mandrel bent. Just go with the 2.2 intake
2.4 intake manifold is plastic aswell. Another thing i just thought of, it could be the size of the couplers for the throttle bodies is different.
yeaa i got stuck with it damn you CA emissions
ThoR294
10-04-2015 08:44 PM
OrangeCoba
09-25-2015 06:06 PM
