2005 2.2 turbo
#426
#427
#428
well yea i just bought what i need from ebay last night...so its all good..im just having a lil issue with the gasket....they guy i bought it from they run a dismantling service and he says that they dont sale the used gaskets...i told him that i dont give a shait...if does or doesnt...just give me a fucken gasket i told him...so he is going to look for one and if he finds it that he will send it to me....so looks like i should be good...since the one he had pictured clearly shows the gasket on the cover....so i should be fixing my leak here in about 9 days or less....shipping takes for ever
#429
well i installed my new timing cover and a home made gasket....ill put up some pictures later.....i did pretty dam good for my first gasket ever made....well installed everything....and guess what.....i fixed one leak...but it turns out i have 2 leaks.....so in order for me to fix this leak i need to remove the oil pan the timing cover...and the lower portion of the block...i forget what its called...well either way its going to be a bitch....but once i fix that....i should be good...but yea...ill put up some pics of my home made gasket
my home made gasket using a cereal box...fixed my leak...but like i said...i still have one more leak.... i really need my tools back...so i can finish this ****
someone let me borrow some tools
#431
#432
#433
i used the rtv ****...and it didnt work...so this fixed it until i can get the cash to get one from gm...its only a temp fix
#434
i feel your pain. not everyone has money falling out of their ears to do things the "proper" way. as long as you get it done right ASAP, thats all that matters.
#435
i was just making sure that it would fix my leak...and now i know i have another leak so i need to fix that now
#436
#438
breaker bar
tq wrench ft/lbs
15mm socket
18mm socket
magnet
extension in many sizes
when you coming out this way?
#439
I have most of them but not all like the breaker bar. I replied in your other thread aight.
#440
#441
not for a while now. the new sea shore rotation came out for all rates and all ranks from e9 on down. i was supose to be headed out there next xmas but now not till june 2010
#442
#443
yeah it is... i was trying to get out there sooner but my CoC said im a vital asset to the ship to our CO (bull shizzy) so they wouldnt let me do a split tour
#444
yea im done with the B.S. so im getting out in January...i should have been out in August but i extended a few months...and i have now made up my mind that im done with the B.S.
#445
well i have good news and bad news......the bad news is.....
that my car still dont start due to my tune and these stage 2 cams that im trying to get rid off for some stock 07 cams.
the good news!!!!
i no longer have an oil leak...after a month or so i finally got to fixing the dam oil leak.....im so proud of myself....lol...and my special helper who stood by my side holding the light....my wife....lol
the good news!!!!
#447
now if for some reason i dont sell these cams...do you think i can compensate for them with some adjustable cam gears or do you think that just a tune will fix my problem....
#448
Shoot me a pm, I'll get you back up and running.
#449
I'm old school
Did you know the only difference between LSJ cams and L61 cams are the timing? They have the exact same grind.
