2005 2.2 turbo
#502
#505
well heres an update...i finally got my tools back today and i can finally finish what i started not only that...i separated from the marines last month and today i found a new job....stuff is finally coming together....so ill be working on my car these next couple of days...but for sure ill have it running before or on saturday
#507
#508
#512
#513
awwwww......... im seriously confused now as to why this car does not start....it so weird....the timing is perfect...the fuel is spraying like no other...and the spark plugs are firing....dam ***** even shocked me...kinda felt good...lol...
p.s..... never buy ebay spark plugs...they were damaged and never sparked so i went i bought new ones
is there a possibility that the spark plugs are firing at the wrong time?....like mayb they are firing when the valves are open and not when they are closed due to computer error?
#514
#515
yes its cranking...but it wont even start...it will combust at odd times like the timing is off...which i know that the timing chain is perfect....which leads me to believe that the ecu is throwing out the wrong signal at the wrong time which is causing it not to fire correctly....is this even possible?
#516
#518
also stupid question but are you sure you're maf isn't damaged or only partially plugged in
#519
fuses are good
connections are good
maf is hooked up and not damaged
ill have to call vince and see...but that means i need to re order the tuner
#521
well the tune im running is good tune up to 5.8krpm...i dont think its the tune that doesnt let it start...but im going to get in touch with vince as see what we can do
but not yet cuz i dont have much money to my name right now...im still waiting for 6k from the marine corps that i should see in about 10 days and i start working next week
#522
have you checked to make sure that the coil pack is firing when conected on the car?
same for injectors?
#523
no vac leak
coil pack is good i checked and i swapped with another one
fuses are good
the chain timing is on spot....but im also thinking that the spark timing is off.....that the ecu is making it fire at the wrong time
fuses are good
either that or injector pulse with .. but if you'd ruled out all the mechanical possibilities that sounds like its a tune thing .. i'm sure he'll work with you you didn'thave a built engine before ... 8.9:1 CR probably doesn't like your previous tune
#524
and injectors are firing everytime...i pulled the rail and injectors out to see if it was spraying and yes they are
he might work with you on that ,.. yea i dunno why i said ignition timing.. oh wait .. cuz i haven't slept and i'm not thinking .lol
#525
yes the coil pack is firing...as well as the new spark plugs....shocked the **** out of me while i was testing this.....i missed that feeling...lol
yea ive considered the 8.9:1 CR as well...but i talked to vince and he said it should start....either way im ordering a tuner in about a week or two depending on cash
