2006 Pontiac Pursuit 2.2L build going supercharged...
I may as well make a thread to track my progress, I'll keep my first post in this thread updated for simplicity sake and I'll make bumps for updates.
Current phase: Collecting parts.
What I have currently:
- Eaton M62 supercharger
- LSJ intake manifold
- K&N SS/SC CAI
- LSJ throttle body
- LSJ Heat Exchanger
- LSJ Intake manifold gasket
- 42# injectors + harnesses
- Stage 2 belt
- intercooler pump
- 2.8 & 3.1 pulley (although I might just use the 3.1 pulley)
- Large assortment of clamps & bolts
- & a bracket (I think heat exchanger pump bracket??)
- ZZP pillar tri-gauge pod.
- Trifecta cable (heck yes, I am a dealer now!!!) & tune purchased.
In limbo for now:
- ZZP Adjustable Tensioner pulley -- found/purchased & pending shipment.
- LSJ Idler Pulley -- found/purchased & pending shipment.
- LSJ MAP/IAT2 sensor - pending shipment
- LSJ Upper rad hose - pending shipment
- LSJ Alternator Bracket - pending shipment
- Cobalt SS/SC window washer fluid reservoir & pump - pending shipment
What I need:
- Three gauges to fill my pods (1- BOOOOST!, 2- Wideband, 3- Interceptor)
If anyone else wants to help me with what else I need or should add to the list, let me know! Also if you have parts I'm looking for, let me know as well!!!
My target date was suppose to be end of April, now due to my budget, more like end of May.
Thanks for looking, my next update will probably be after I order parts in 2 weeks from now
UPDATE::: 05/05/2009 Found a tensioner, pending shipment from a CSS member
UPDATE::: 05/07/2009 Not purchasing from original seller since no response but found another CSS member who will be selling me his ZZP Adjustable Tensioner & tensioner piston & Idler pulley
UPDATE::: 05/13/2009 All parts (minus gauges) HAVE BEEN PURCHASED!!! Should all hopefully be in Washington by next Friday latest... if not then I may need to wait 1 more weekend to supercharge .
- K&N SS/SC CAI
- LSJ throttle body
- Stage 2 belt
- intercooler pump
In limbo for now:
What I need:
Oh I know... you're on G5CLUB . I think I may need to get some part #'s off of you because I will be needing a few things... I'll fire you a PM over there with some parts I was looking at buying from GMPD but instead may as well get from you
Thanks bud. I'll get you hooked up.
I'm going to put an interceptor in the 3rd one.
Actually, they don't. You can get an interceptor without the Cobalt logo. If you go to the interceptor website you'll see it. I'm going to get the one with the black bezel, white face and red numbers.
Ok fine fine fine... I'll get interceptor lol... There is someone locally who has one so maybe I'll give him a shout and see if he still wants to sell to me.
These guys really went out of their way to do the How-To's. Hunter has been very valuable to me. There are some small things left out in the How-To's, but maybe when you're in there it may be obvious. But, in preparing for the install, it makes me nervous.
I looked at Hunters How-To again last night. I'm trying to figure out where the IC pump (bracket) gets mounted, but it is not clear... and maybe just because I'm not reading it properly, or it will be clearly obvious when I go to do it.
You were asking about the brake booster?
you can see it underneath the far bolt to the right that is circled in red.
for the pump bracket:
this piece (specifically those top two holes closest to the camera
bolts up to the lower manifold bracket
through the bottom two holes.
Thanks for the appreciation guys. it means a lot to me
As for the mount. This makes a little more sense to me. I guess in your how-to you showed bolting in the intake manifold mount... but never pictured how the actual IC pump mounting bracket is attached.
So, I mount the intake manifold mount to the block. Put the IC pump bracket through the bottom two holes. Now, do the IC pump mount brackets go through the bottom intake mount and through 2 more holes in the block, do the bolts go through and they have nuts on the back of the bracket or do the bolts just screw into the bottom of the bracket and not go through the back or anything.
Everyone is talking about you dude, lol, with your help, and it means a ton to us. This is going to do nothing but make my install day easier because I have a much better understanding of what I'm getting into.
It is #15 in the following link.
http://www.gmpartshouse.com/cobalt/c...gercooling.pdf
