2006 Pontiac Pursuit 2.2L build going supercharged...
#76
We need bolts... so that we need to shop for.... other than that... we need some hoses which we can get locally & bolts can be purchased locally... mmm.... what else... AH yes, Gene is shipping the rest of my parts as a 2 day shipping so they should be there by Friday... mind if I stay the night tomorrow night down there Tom? I'll collect up as much parts as I can bring back, get you to write me up a gift receipt hehe...Then I'll head back up here and starting taking my car apart!!! Wait for you on Saturday night/Sunday and we'll throw the supercharger on!
#81
OK SO... everything is installed and working great except for one thing... car can't decide what it wants to idle at... yes I'm tuned but can't get the tune fine tweaked until my idling issue & this other issue is resolved and I'll explain what my other issue is...
I keep throwing a P0141 & a P0036 (I threw a P0030 the other day but that didn't come back, now its just the 36) saying the that the o2 heater sensor issue.... so I changed O2 sensors and unplugged battery, plugged back in and fired up, Vince still can't get an O2 reading and I threw another CEL... I took for a drive down the street and back (NOT recommended FYI until car is fixed) and left idling and cleared O2 code, did another data log this time O2 sensor working just fine.... send Vince the data log, looks good, gets back to me with an updated tune & I throw CELs for P0141 & P0036 again... UGH.. the sensor is good because its the second one I've thrown in (so I know the first one is good), wiring is good since I unplugged and tested all 4 prongs in the connection (read a 12V, 0.4V, 0.5V & ground).... I don't see the wire touching anything or NOR is it shorting anywhere visually....... I checked the EMSN fuse, looks good but I changed it anyhow..... any other recommendations? The rpm's fluctuate between 900-1500 then steady at about 1450........ ugh.... I need suggestions!!
#82
is it throwing a front 02 sensor or rear 02 sensor code...cause mine throws the rear one even though vince tuned it out...i need to work on that with him lol
you sure your code isnt a P0136 not a p0036???? cause p0136 is rear o2 sensor code
#83
EDIT: so vince said that was for the rear o2 but still having a problem with the front o2 sensor not reading in the data logs.... idling at 1200 rpm now with AFR @ 17.2/17.3... so its running lean.. Vince is looking it over to see what further can be done.
#85
141 & 0036 are for the rear o2.... but he still says no front o2 readings ... I really hope he gets back to me with good news later because my car is being a HARSH female dog right now....
#87
One thing to consider is that you bought a used LSJ throttle body right? A lot of people are posting that when they clean the LSJ TB that the idle is all over the place. I cleaned my TB but I didn't try and move anything.
If I have this problem upon install that is one of the first things I'm going to look at.... so you might want to not rule out the TB. You don't know if the person before you cleaned it up, or we don't know if you cleaned it up, etc.
Also, I need to get that cable from you ready. I'm running out of patience on waiting for my friend to help me install so I'm going to pull the trigger soon.
#88
As for tb... its not the tb... I've idled just fine and it appears to work just fine... my o2 sensor not responding though is a diff situation though.... arg... damn thing. I'll keep fiddling with it later.
#90
thats why I wanted to do it here lol... I would have also needed to wait to pick up my car until I got a passport hahaha. that woulda sucked!
#91
OK so... here's the scoop.. supercharger pissing me off so supercharger is coming off my car .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................. while i retighten all the bolts then reinstall lol... had you guys on edge... I know it... mahaha... I hope that fixes it though... going over every bolt making sure tightened to torque spec & look for any visual issues with supercharger off then back on it goes and cross my fingers!!! I'll be trying that this weekend.
ThoR294
10-04-2015 08:44 PM
Delta coupe
09-30-2015 08:11 AM
